General Information
General
Little green collar thing that holds the pass axle seal on MK2 020
Topic: Little green collar thing that holds the pass axle seal on MK2 020 (Read 6189 times)
December 24, 2009, 09:18:55 pm
maxfax
December 24, 2009, 09:18:55 pm »
On the MK2 020's there a little green sleeve like thing that drives into the trans case to hold the passenger axle flange seal.. I managed to bugger mine up when I changed the seal the last time.. Anyone have a part number, source, or even a proper name???
December 25, 2009, 06:16:29 am
FineFrank
Re: Little green collar thing that holds the pass axle seal on MK2 020
December 25, 2009, 06:16:29 am »
I bought mine for my 83 at Germanautoparts.com. Meistersattz number 020 498 085. It was called a drive flange seal kit and came with the oil seals as well. I believe they're the same.
Frank Longtine
1983 Rabbit Diesel 4 dr/ 1.6NA
1997 Rokon Trailbreaker
1984 Ford F-150/ 300-6
"The welfare of humanity is always the alibi of tyrants" -Albert Camus-
December 26, 2009, 04:04:27 am
maxfax
December 26, 2009, 04:04:27 am »
Thankyou Frank!! I still didn;t find it on their site, but I'll give them a call.. At least now I have something to go by other than "Little green sleeve thingy"...
December 26, 2009, 05:16:17 pm
December 26, 2009, 05:16:17 pm »
Is this thing used to hold the seal in or for something for it to bottom on? I didn't notice one last time I changed the seals on my box
December 26, 2009, 06:32:38 pm
maxfax
December 26, 2009, 06:32:38 pm »
More or less it looks like an adapter sleeve.. It drives into the trans case, and the seal drives into this piece.. This particular trans came from an '85 Jetta..
Here's a pic I stole from Brokevw..
December 26, 2009, 08:58:25 pm
December 26, 2009, 08:58:25 pm »
Some 020s have 'em, some don't... never heard any reliable explanation as to why.
December 26, 2009, 09:22:53 pm
maxfax
December 26, 2009, 09:22:53 pm »
My observation so far has been that it was only the later 020's with the spring behind the axle flange had this thing... All my earlier (pre 83ish?) do not have this sleeve or the spring..
I'm finding all sort of pics, but no reference to a part number...
I suspect someone thought it was part of the seal, and drove it out.. They did manage to get it somewhat back in shape and gooped it with RTV but it still leaks a bit.. I didn;t make it much better when I changed the seal.. I'm doubtful that I could get one of these out of another trans and still have it be usable.. I guess worst case scenario I can maybe take one of my trashed trannies and swap that half of the case.. I've been considering a teardown and inspection anyways...
Last Edit: December 26, 2009, 09:54:35 pm by maxfax
December 26, 2009, 11:52:11 pm
maxfax
December 26, 2009, 11:52:11 pm »
I must have had my head in dark places when I was looking earlier... Looks like BrokeVW can get em.. Sounds like a good excuse to disect my trans and see if I'll need anything else.. Then on to the synthetic fluid so I can shift in the cold!
December 27, 2009, 05:02:05 pm
rallydiesel
December 27, 2009, 05:02:05 pm »
I thought it was something do do with the "minislip" characteristic of the 020 trans. I'm sure you could find more specific info on the vortex or even im broke through there.
1991 Jetta TD - sold
2001 Golf TDI - Son's
December 28, 2009, 01:34:52 pm
December 28, 2009, 01:34:52 pm »
Exactly. The anti-rattle spring added around 1983-84 extends the flange outward a small amount, so in order to have the seal ride on the correct part of the flange, they added the green cone to compensate.
I've had a hard time trying to remove the seal without bodging up the cone so I almost always order an extra if I'm doing a seal job.
'86 Golf N/A Diesel -->Wife's car
General Information
General
