Author Topic: New Intercooler Mounting Idea  (Read 10314 times)
December 22, 2009, 07:27:44 pm
Doakster
  • 291
« on: December 22, 2009, 07:27:44 pm »
I have an idea on an spot to mount an intercooler, maybe it's not a new idea, but i don't recall it being done before.
I'd like to remove the stock air box, install a cone still filter and just in front of the cone filter, mount a saab blackstone intercooler. I would build a  new protective box around the filter and intercooler for heat protection and to some what channel the air around the intercooler and filter.
I may have to tilt the blackstone a little bit to allow it to fit.
Thoughts on this? I really can see the intercooler interfering with the filter air flow and i think the intercooler would have a far amount of air flow. It would also allow for short runs of piping all on the timing belt side of the engine bay.
Does anyone have the demensions of a blackstone intercooler or know of another intercooler that is about that size and could fit in the air box location?
1991 VW Jetta 1.6TD (Formally an ECO), Giles LDA Pump and Injectors, Techtonics 2.25" Down Pipe and Exhaust system, Rebuilt Trans with 3.94 final drive and a Peloquin Limited Slip Diff, Front H&R Sport Springs, MK4 VR6/1.8T front brakes, Single Round Headlight Conversion.
Reply #1December 22, 2009, 07:42:47 pm
Doakster
  • 291
Re: New Intercooler Mounting Idea
« Reply #1 on: December 22, 2009, 07:42:47 pm »
Yeah that was my biggest concern as far as not being efficient, would be convenient for a mounting location, but don't think it would be best for heat transfer.
I think my only other logical option is a FMIC, tucked behind the opening of the bumper, not much room with the AC condenser, and not much room to run tubing lines to the front either.
Reply #2December 22, 2009, 09:32:34 pm
mystery3
  • 774
« Reply #2 on: December 22, 2009, 09:32:34 pm »
How much do you use the a/c in Maine?
Has anyone ever mounted an IC in the raintray? A long skinny one obviously.
Reply #3December 22, 2009, 11:48:18 pm
gldgti
  • 488
    • http://scramjetsite.8m.com
« Reply #3 on: December 22, 2009, 11:48:18 pm »
bad idea..... for the reasons listed above. plus the little saab intercoolers arent much chop in a diesel. i fooled around with top mount 'coolers, ducted air and stuff, and it all worked, but not even half as well as my final solution:
http://www.vwdiesel.net/forum/index.php?topic=17437.0
hope that helps :-D
'91 Golf Cabrio 1.9TD
Reply #4December 23, 2009, 03:25:22 pm
Doakster
  • 291
« Reply #4 on: December 23, 2009, 03:25:22 pm »
hope that helps :-D
Thanks for the info, seems like you have much more room to work with in the front bumper on your  than the mk2 even with big bumper on my car, i think i might end up doing a front mount, but i think i'll have a tough time getting the piping routed from the engine bay through the bumper, on the passenger side i have an AC line right in the way of the logical place to run the piping to the front bumper and on the driver side the AC dryer is right in the way.
Reply #5December 24, 2009, 09:41:47 am
hamradio
  • 282
« Reply #5 on: December 24, 2009, 09:41:47 am »
I don't think the saab blackstone IC is worth it (in 9000 or 900 forms).  The 9000 one, while large, is restrictive.  The 900 one, while a nice little package, gets heatsoaked so quickly.  My 1991 900 turbo has one, and it is really a terrible intercooler.
Reply #6December 24, 2009, 02:56:21 pm
nime01
  • 14
« Reply #6 on: December 24, 2009, 02:56:21 pm »
Here's my Forge FMIC, not yet hooked up (changing HG at the moment). No problem mounting this.
Reply #7December 24, 2009, 07:57:54 pm
Doakster
  • 291
« Reply #7 on: December 24, 2009, 07:57:54 pm »
Nime01, couple questions, that care doesn't have AC does it, where did you get the IC and what are the dimensions?
There is an AC line right in the way on my car where your passenger side piping comes from the IC into the engine compartment, that i'm not sure i can get around.
Reply #8December 25, 2009, 12:57:26 am
nime01
  • 14
« Reply #8 on: December 25, 2009, 12:57:26 am »
No, it doesn't have A/C, so it is probably a lot easier to fit. The IC is made by Forge Motorsport, 60mm core, 680 x 80 x 200mm
http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=0013&product=FMINT104UNI
Reply #9December 25, 2009, 03:26:20 am
stewardc
« Reply #9 on: December 25, 2009, 03:26:20 am »
Put the battery in the trunk and put the Blackstone flat where the battery is. Install a nice little fan on it to aid airflow.
Reply #10December 25, 2009, 05:18:57 am
Doakster
  • 291
« Reply #10 on: December 25, 2009, 05:18:57 am »
I do realize that is an option, I'm just trying to avoid that if I can, it would be fairly easy for me to do, but i don't really want to relocate the bat. and add a fan.
Reply #11December 25, 2009, 08:19:39 am
blackdogvan
  • 574
« Reply #11 on: December 25, 2009, 08:19:39 am »
I'm pretty sure these guys will have something to go pretty much anywhere. I just got a AWIC kit from them, the quality is actually pretty good. I hunted around quite a few ricer forums before i ordered & found quite a few good reviews of their products.
www.cxracing.com
1991 Vanagon 1.9 mTDI
Reply #12December 25, 2009, 08:48:23 am
« Reply #12 on: December 25, 2009, 08:48:23 am »
Reply #13December 25, 2009, 09:13:31 am
« Reply #13 on: December 25, 2009, 09:13:31 am »
we were just going over this in another thread a couple days ago, about how restrictive the blackstone intercoolers are and how easy it is to heat soak them.
Reply #14December 28, 2009, 09:12:01 am
wildenbeast
  • 50
    • The WILDENBEAST
« Reply #14 on: December 28, 2009, 09:12:01 am »
www.cxracing.com
I am hoping you will post the install and results compared to your current setup.  The site you referenced has a lot of nice stuff...
1990 Syncro Adventurewagen
1.9 Turbo Diesel (AAZ)
http://billwildenberg.shutterfly.com/vwvanagon
