Author Topic: New Intercooler Mounting Idea  (Read 10327 times)
Reply #15December 28, 2009, 09:16:31 pm
Dewey
  • 32
Re: New Intercooler Mounting Idea
« Reply #15 on: December 28, 2009, 09:16:31 pm »
I think my only other logical option is a FMIC, tucked behind the opening of the bumper, not much room with the AC condenser, and not much room to run tubing lines to the front either.
Thats how i fit mine. Car is equipped with AC (nice and cold too  ;) ) and an oil cooler fastened to the backside of the intercooler. It is a tight fit, the bumper is trimmed to clear and the lower rad support bracket had to be removed. 1.9 with a 1.6 head, 20psi, some pump mods, and it has never gotten hot. (the "vents" seen in the plate recess are no longer there)
I also ran my intercooler piping as seen here. Not the most efficient routing due to length of the piping (close to 5 feet was used) but i only experienced a 2psi drop across the entire system. Turned the airbox on its side, cut the bottom of it out, ran the hot side down through a factory hole in the inner fender, and the cold side is run between the tranny and PS resevior, with a couple bends to connect everything under the car.
Reply #16December 29, 2009, 08:22:17 am
« Reply #16 on: December 29, 2009, 08:22:17 am »
omg... that is one sexy blue jetta.
Reply #17December 29, 2009, 05:04:17 pm
Doakster
  • 291
« Reply #17 on: December 29, 2009, 05:04:17 pm »
Dewey....nice setup, how much did you have to cut out of the front bumper, to get the IC to fit?
Also, how does the radiator hold up with no lower support?
« Last Edit: December 29, 2009, 05:08:44 pm by Doakster »
1991 VW Jetta 1.6TD (Formally an ECO), Giles LDA Pump and Injectors, Techtonics 2.25" Down Pipe and Exhaust system, Rebuilt Trans with 3.94 final drive and a Peloquin Limited Slip Diff, Front H&R Sport Springs, MK4 VR6/1.8T front brakes, Single Round Headlight Conversion.
Reply #18December 29, 2009, 07:05:47 pm
Dewey
  • 32
« Reply #18 on: December 29, 2009, 07:05:47 pm »
The lower crossmember, which supports the rad, is still there, what i did remove was just the one bolt, in the center, at the very bottom of the rad support (what the headlights, grill and top rad mounts are attatched too).
As for how much i trimmed, i just kept trimming until the fit was nice and tight, this pic shows about how much i had too trim.
I can get measurements of the intercooler since the car is in pieces at the moment. the intercooler is a Yonaka unit, flows pretty good, and has been good for my needs. This is how it is mounted. Super simple, not too much is covered by the bumper, the temp difference side to side of the intercooler is noticable by touch. (this is an old pic, roughly 2 years ago, but car is in the same amount of disassembly now, never ending projects it seems  :P )
Reply #19December 29, 2009, 07:11:08 pm
Doakster
  • 291
« Reply #19 on: December 29, 2009, 07:11:08 pm »
Looks nice, might have to do something similar
Reply #20December 29, 2009, 07:15:38 pm
Dewey
  • 32
« Reply #20 on: December 29, 2009, 07:15:38 pm »
Thank you very much for the kind words :D. Im very proud of the work ive done and the way its turned out.
Reply #21December 30, 2009, 02:50:37 am
  • 3468
    • McScrubbins Body Wash
« Reply #21 on: December 30, 2009, 02:50:37 am »
Yeah that was my biggest concern as far as not being efficient, would be convenient for a mounting location, but don't think it would be best for heat transfer.
lots of us have  done FMIC. me for example...
slightly larger than dewey's. It's almost 4 inches thick, i had to remove a lot of bumper material.
And like dewey's mine is very noticeably cooler from one side to the other. like night & day. mine cools well enough that i can touch the intake manifold and it's relatively cool.
minor modification required.
« Last Edit: December 30, 2009, 02:54:11 am by Smokey Eddy »
Reply #22December 30, 2009, 06:32:18 am
polo_td
  • 65
« Reply #22 on: December 30, 2009, 06:32:18 am »
Hi.
If u use the MB sprinter IC u brob. dont need to do so much modifying.
Otherwise the BMW 525tds IC is a small one aswell.
Take a look at them.
here´s pic of the BMW´s
24" between in/outlets.
3" thick
3" high.
thomas
Reply #23March 25, 2010, 03:00:17 pm
nime01
  • 14
« Reply #23 on: March 25, 2010, 03:00:17 pm »
Finally finished mounting my IC, as the HG went bust some time ago, replaced with AAZ HG now! Noticeable difference, the intake manifold is ice cold to the touch, even after some inspired driving on max boost (set at 1.4 bar/20 PSI)
Before connecting the IC, EGTs were at 754℃ max, now I'm struggling to reach over 662℃, i.e. a 92℃ reduction in EGT. So there is some cooling going on.. :)
« Last Edit: March 25, 2010, 03:03:58 pm by nime01 »
Reply #24March 25, 2010, 03:45:19 pm
rallydiesel
  • 1880
« Reply #24 on: March 25, 2010, 03:45:19 pm »
What kind of tubing is that black stuff?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #25March 25, 2010, 03:52:42 pm
truckinwagen
  • 1895
« Reply #25 on: March 25, 2010, 03:52:42 pm »
you mena what smokey eddy is using?
its ABS pipe, commonly used for drain, waste and vent piping in construction.
it is very robust, resists heat transfer and will hold a remarkable amount of pressure.
it is also easy to assemble with a hand saw, ABS cement and the appropriate couplers.
I thought of using it as well, but went for aluminized steel tubing and silicone couplers.
83 Opel Kadett Diesel
Reply #26March 25, 2010, 03:52:58 pm
stewardc
« Reply #26 on: March 25, 2010, 03:52:58 pm »
But you have a turbo and intercooler on an engine with a NA pump. It must work like crap.
Reply #27March 25, 2010, 03:56:46 pm
rallydiesel
  • 1880
« Reply #27 on: March 25, 2010, 03:56:46 pm »
I mean what nime01 is using.
Reply #28March 25, 2010, 03:58:05 pm
truckinwagen
  • 1895
« Reply #28 on: March 25, 2010, 03:58:05 pm »
looks like reinforced silicone to me.
just like a coupler, but longer.
Reply #29March 25, 2010, 05:25:03 pm
somolovitch3
  • 290
« Reply #29 on: March 25, 2010, 05:25:03 pm »
If you do not mind modifying hood, place the IC above the space between the radiator and the engine. Using a reverse "scoop" to modify the airflow, and a "real" scoop to get "cool" air to your intake.
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
