Author Topic: turbo timer...?  (Read 4504 times)
December 12, 2009, 01:21:30 am
79rabbit4dr
turbo timer...?
« on: December 12, 2009, 01:21:30 am »
What are some good brands for turbo timers?
also thinking about remote start, suggestions?
Reply #1December 15, 2009, 12:12:36 am
OM617
Re: turbo timer...?
« Reply #1 on: December 15, 2009, 12:12:36 am »
The best turbo timer is you. Wait 5 seconds before turning the engine off. Longer just wastes fuel.
Reply #2January 03, 2010, 09:27:49 am
Re: turbo timer...?
« Reply #2 on: January 03, 2010, 09:27:49 am »
5 seconds? thats all? doesnt seem like a turbo and manifold could cool down in 5 seconds. or are you just saying 5 seconds just to let it spin down?
Reply #3January 03, 2010, 11:32:14 am
rabbitman
  • 2788
Re: turbo timer...?
« Reply #3 on: January 03, 2010, 11:32:14 am »
When I had the turbo installed I waited until the egt gauge pegged at the bottom (250F) before shutting down, a little longer if I'd been running it real hard.
That method only measures the exhaust temp though so the turbo itself is probably really hot still.
Reply #4January 04, 2010, 07:29:06 am
Re: turbo timer...?
« Reply #4 on: January 04, 2010, 07:29:06 am »
if the exhaust coming out was 250*, the turbo probably wasnt that ridiculously hot.
Reply #5January 05, 2010, 07:04:16 pm
OM617
Re: turbo timer...?
« Reply #5 on: January 05, 2010, 07:04:16 pm »
Diesel exhaust is far cooler than g@ssers. 5 seconds is more than enough to make sure its cool and at its lowest speed.
Reply #6January 05, 2010, 09:42:42 pm
blackdogvan
  • 574
Re: turbo timer...?
« Reply #6 on: January 05, 2010, 09:42:42 pm »
While the gasses may be cooler after 5 seconds, I don't think that's long enough to cool a heat soaked turbo. Its the latent heat from your exhaust manifold & turbine housing that cokes the oil in the journal bearings after you shut down & the oil isn't flowing.
So... buy a house at the bottom of a hill & never buy a turbo'd car from someone who lives at the top of one!
1991 Vanagon 1.9 mTDI
Reply #7January 05, 2010, 09:50:39 pm
rabbitman
  • 2788
Re: turbo timer...?
« Reply #7 on: January 05, 2010, 09:50:39 pm »
Hahaha......that's what I was trying to say ;D
Reply #8January 07, 2010, 11:17:45 am
Re: turbo timer...?
« Reply #8 on: January 07, 2010, 11:17:45 am »
i usually liked to idle my car for around 30 seconds to a minute usually. i never had a EGT gauge, so i figured i might as well be safe and idle it down good.
