Author Topic: VANAGON/T3 SILICONE COOLANT HOSES *GROUP BUY* SIGN UP  (Read 40702 times)
December 04, 2009, 08:12:24 pm
Syncroincity
  • 727
« on: December 04, 2009, 08:12:24 pm »
First, read THIS POST by GEE-BEE; offering hose construction services.
Now, to keep things orderly, I want to start a separate thread to gather signatures for a group buy on VANAGON DIESEL coolant hose sets. I'll be providing a master set for the molds. No set price yet, but estimated between $275-$325. We need at least 25 buyers for optimum pricing.
 Please spread the word to all Vanagon owners you know, original Diesel and IDI/TDI conversions will all be able to use this hose set. New rubber sets are NLA here.
Firmer pricing will be set once the mfg. sees the actual hoses.
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
'04 Passat Variant GLS 4Mo 5MT
Reply #1December 04, 2009, 09:50:06 pm
FrankGRUN
  • 1
Re: VANAGON/T3 SILICONE COOLANT HOSES *GROUP BUY* SIGN UP
« Reply #1 on: December 04, 2009, 09:50:06 pm »
I will sign up for a set, particularly if it follows 1983 Diesel Vanagon hose group. I would encourage an interface to the 1983 Coolant Reservoir as the 1982 version didn't support the coolant level switch. The hose connections were larger than the '82 and sleeves to fit the earlier version are easier to implement than necking up a size.
Frank Grunthaner
Reply #2December 04, 2009, 11:08:31 pm
williamtaygan
  • 33
    • Arctic Vegwerks
« Reply #2 on: December 04, 2009, 11:08:31 pm »
I'm in for a set of 1982 1.6NA hoses for ~$300.  Might be in for 2 sets??
Will.
1981 1.6 NA Pickup
1982 1.6 NA Westfalia
1990 1.6 NA Jetta (not running)
1991 1.6 eco Jetta
1994 1.6 TD Jetta
Reply #3December 05, 2009, 01:39:29 am
Syncroincity
  • 727
« Reply #3 on: December 05, 2009, 01:39:29 am »
Uh-Oh. ::) Any other differences through the years? I'm using a Euro JX hose set like this:
JC McCavitt
'98 Jetta Wolfie
Reply #4December 05, 2009, 07:36:41 am
vwgreenbean
  • 1
« Reply #4 on: December 05, 2009, 07:36:41 am »
 I would be in for a set just let me know how and when.
Thanks
Eric
Reply #5December 05, 2009, 07:57:42 am
blackdogvan
  • 574
« Reply #5 on: December 05, 2009, 07:57:42 am »
Keep me on your list too! I use a coolant level switch res so i'll be following that discussion too.
thanks for championing this btw!
1991 Vanagon 1.9 mTDI
Reply #6December 05, 2009, 08:32:02 am
skifree
  • 32
« Reply #6 on: December 05, 2009, 08:32:02 am »
I need a set for my 82,that set looks larger on the ends of the hoses.,
Reply #7December 05, 2009, 09:08:27 pm
captainpartytime
  • 39
« Reply #7 on: December 05, 2009, 09:08:27 pm »
I'm in for a set also. I have an '82 diesel westy that is being converted from the original 1.6 na to a '90 turbo ecodiesel.
-Kerry
1982 Diesel Westfalia Vanagon
1989 Wolfsburg 7-Passenger Vanagon
Reply #8December 05, 2009, 10:10:28 pm
Syncroincity
  • 727
« Reply #8 on: December 05, 2009, 10:10:28 pm »
Here's some eye candy for you; some of the manufacturer's other offerings... these are for a MKIII VR6
JC McCavitt
'98 Jetta Wolfie
Reply #9December 06, 2009, 08:17:40 am
CdnVWJunkie
  • 309
« Reply #9 on: December 06, 2009, 08:17:40 am »
I'm in for at least one set.  I prefer the JX as well.  Is there a proposed completion/delivery date (roughly)?
Thanks.
Rob
Reply #10December 06, 2009, 09:47:22 am
williamtaygan
  • 33
    • Arctic Vegwerks
« Reply #10 on: December 06, 2009, 09:47:22 am »
How do the JX hoses compare to the TIICO hoses at Van Cafe?
http://www.van-cafe.com/home/van/page_150
I'm a big fan of a universal hose that would work with the smaller (and NLA) '82 and '83 coolant pipes, as well as the smaller '82 coolant reservoir.  Stepped ends could work.
I'm am curious, however, about hose length differences between the '82 stock mounts (2" forward) and the '83 and later mounts.  I guess there could be length differences between the '83 coolant pipes and the later larger plastic pipes as well..
« Last Edit: December 07, 2009, 09:03:23 am by williamtaygan »
1981 1.6 NA Pickup
1991 1.6 eco Jetta
1994 1.6 TD Jetta
Reply #11December 06, 2009, 10:44:39 am
GEE-BEE
  • 1604
« Reply #11 on: December 06, 2009, 10:44:39 am »
Those arent silicone, the mfg can always make the hose longer to meet the need's of both models, they can be reduced at the end's also for those model's
It's the bends we have to be careful about
Please use silicone type clamp's: breezeclamps.com
I will have more info on clamp's from another vendor for the silicone hose kit, it will be a seperate item....
Cheer's to all for starting a solution to a small problem..
I would consider these hose a Lifetime Type
Gee-Bee
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #12December 06, 2009, 04:20:36 pm
westyventures
  • 45
« Reply #12 on: December 06, 2009, 04:20:36 pm »
Interested in 2-3 sets
Karl Mullendore
www.westyventures.com
Reply #13December 06, 2009, 08:49:35 pm
Syncroincity
  • 727
« Reply #13 on: December 06, 2009, 08:49:35 pm »
Would it be worth it to make the front radiator hoses as well? Not the 14' fore-aft hoses, just the radiator connections...
I can't imagine what the long hoses would cost to make and ship... :o
JC McCavitt
'98 Jetta Wolfie
Reply #14December 07, 2009, 04:54:49 am
kd4yor
  • 37
« Reply #14 on: December 07, 2009, 04:54:49 am »
it's amazing there isn't a company in North America who can make these and be price competitive.
