Author Topic: what caused this? injector? timing? what?  (Read 2470 times)
November 28, 2009, 08:25:10 pm
riceatingrabbit
  • 89
« on: November 28, 2009, 08:25:10 pm »
last time i had the head off my rabbit, two pistons were pitted like this...
I didn't have the time or money to replace them, so i just put it together "as is"...
I'm wondering if you guys know what typically causes pitting like this? I'm going to be tearing down my engine again here in a few weeks, and Im trying to gauge the importance of replacing the pistons...
what do you guys think?
« Last Edit: November 28, 2009, 08:26:56 pm by riceatingrabbit »
Reply #1November 28, 2009, 08:52:39 pm
truckinwagen
  • 1895
Re: what caused this? injector? timing? what?
« Reply #1 on: November 28, 2009, 08:52:39 pm »
bad nozzle spray.
a worn or clogged nozzle will not spray properly, causing heavy carbon deposits and piston erosion.
-Owen
83 Opel Kadett Diesel
Reply #2November 28, 2009, 09:00:35 pm
riceatingrabbit
  • 89
« Reply #2 on: November 28, 2009, 09:00:35 pm »
that kinda what i was leaning towards..
so, given that, if i replaced the nozzles, am I ok to run those pistons? ive scene people run pistons with huge valve divots in them and be ok...
I am planning on turbocharging this motor after this next tear down...
Reply #3November 28, 2009, 09:22:39 pm
truckinwagen
  • 1895
« Reply #3 on: November 28, 2009, 09:22:39 pm »
you should be fine as long as the erosion does not go to the rings
