Author Topic: Too much advance on Ip Timing  (Read 5608 times)
November 27, 2009, 12:13:59 pm
jbturgeon
  • 71
« on: November 27, 2009, 12:13:59 pm »
Hello folks, i would like to tell my experience as it can be useful for others. Golf 95 1.9td with ac. 366000kms. I had black smoke and i was burning oil and coolant (1 litre per 300 km). I changed the head gasket and t-belt and oil and coolant finally get solve. Other problem,: persistant black smoke on acceleration. So i suspected many things and the only way to solve it was to hook the waste gate open on my t3 kkk turbo. Result: no power over 2800 rpm, clicking sound from injectors, white smoke and poor mileage. I was about to rebuilt my Ip, and redo the whole head gasket job. I was a bit too far... Today, i've decided to talk to an injection specialist for diesel trucks and told me that the main problem was the timing being too much forward and probably 1 or 2 worn injectors. This is to say that diesels needs special care with the injection and timing and there is no need to search too deep for a problem that can be easily solve.
I am finally gonna get this pump timed tomorrow and injectors rebuilt and hope it will solve the problem. I really hope!
I would like to thank everyone who helped me in this engine rebuilt and tell you i will write back with the timing done and the results.
« Last Edit: November 29, 2009, 07:40:22 pm by jbturgeon »
AAZ for life!
Subaru Loyale 4x4
Reply #1November 27, 2009, 12:31:13 pm
jbturgeon
  • 71
Re: Problem solve!! Timing was set way too forward..
« Reply #1 on: November 27, 2009, 12:31:13 pm »
I finally get my pump timed. That was a pain in the a##ss. It was all stuck in some rust... The guy told me it was at about +200 and it is supposed to be set at 0.80 or 0.87 at tdc. Anyway, as this was my second engine rebuilt for a 1.9td, i assume that any problem following a good rebuiding job should be diagnose as a timing problem. A lot of people helped me on this forum and before i thought that the timing of my pump could be an issue, i was about to rebuilt my pump, somebody told me it could vbe my internat governor. I think that when you are experiencing some smoke (black or white), poor mileage, knocking from engine around 2800 rpm, lost of power at high rev, checking the internal timing of the Ip is a cheap way to solve the whole problem because rebuilding an Ip, changing the injectors, boosting the pump will do nithing and will be very expensive. I also think that putting the Ip on stock specs is the best way to have an effecient car (cold starting and pollution). If your car have a starting problem, after diagnising the glow plug, the timing should be the second thing to check. My timing was soo off that when i was engaging any gear, it was like if i didn't know how to shift, the car was really stopping like if i was a non-experienced driver.
Now, my car sounds like if the engine was rubber made. Sounds even better than a TDI (lol) I get the 6 l/100km i am use to have with my other td and i can't wait to go for a long trip!!
I hope this tread will be helpfull for others that try to make it more complicated than it should be.
Diesels are simple machines and keep it simple!
AAZ for life!
Subaru Loyale 4x4
Reply #2November 27, 2009, 02:37:28 pm
« Reply #2 on: November 27, 2009, 02:37:28 pm »
Well said. I am kind of surprised that retarding your timing helped though, unless it was over 1.00mm
Reply #3November 28, 2009, 01:02:41 pm
macka
  • 957
« Reply #3 on: November 28, 2009, 01:02:41 pm »
yea if you read his post
it is a tad more then that lol
Quote from: Vincent Walden
Reply #4November 29, 2009, 07:43:16 am
« Reply #4 on: November 29, 2009, 07:43:16 am »
Maybe it's just one of those days but I don't understand what +200 means.
Reply #5November 29, 2009, 01:51:34 pm
  • 3468
    • McScrubbins Body Wash
« Reply #5 on: November 29, 2009, 01:51:34 pm »
hahahha i actually laughed out loud
yeah what does +200 mean :P
if a pump were set to 2.00 ...
Reply #6November 29, 2009, 07:38:09 pm
jbturgeon
  • 71
« Reply #6 on: November 29, 2009, 07:38:09 pm »
Thx guys for your replies. Sorry for my english for the two first post. I am not always writing what i am thinking! I don't know nothing about timing a pump as you saw(+ 200 was a hyperbole, i don't know the numbers) I only guest it was too far forward. As in any problem resolution, i am always digging too far to find a problem that is right there and not focusing on good things.
With all your help, the problem is solve now. Still a loud sound from the power steering motor being old...
JB
AAZ for life!
Subaru Loyale 4x4
Reply #7December 02, 2009, 09:27:30 am
smutts
  • 720
    ClackClackClackClackClack
Re: Too much advance on Ip Timing
« Reply #7 on: December 02, 2009, 09:27:30 am »
 ;D 2.00mm! It must have sounded like a hailstorm of hammers on a tin shed! My ears hurt just thinking about it!  :P
Reply #8December 02, 2009, 12:40:50 pm
rallydiesel
  • 1880
« Reply #8 on: December 02, 2009, 12:40:50 pm »
Yeah, and not too healthy for the pistons and rods.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #9December 03, 2009, 07:33:20 pm
« Reply #9 on: December 03, 2009, 07:33:20 pm »
I have my N/a timed to 0.040" or 1.02mm. Runs great, a little hailstormish, but great power.
Reply #10December 03, 2009, 07:41:12 pm
« Reply #10 on: December 03, 2009, 07:41:12 pm »
Great power and NA don't belong in the same sentence lol :D
Reply #11December 03, 2009, 07:44:03 pm
« Reply #11 on: December 03, 2009, 07:44:03 pm »
Hahaa, well you come drive my 600,000 Mile jetta and tell me it doesn't have some serious balls. lol I mean i was expecting slow being its an 81 and has well over 600k on the clock... but hot damn.. a few mods and this thing will screammm
Reply #12December 04, 2009, 02:34:47 am
  • 3468
« Reply #12 on: December 04, 2009, 02:34:47 am »
Jeremy, i really need to post a video of my 1.6 and show you :P then you do the same!
Reply #13December 04, 2009, 05:05:40 am
« Reply #13 on: December 04, 2009, 05:05:40 am »
it wont do that much awesome.. it is an N/a after all. lol
