Author Topic: mk2 1.9 td swap. pics and questions  (Read 2508 times)
November 26, 2009, 09:03:25 pm
brandon5
  • 88
« on: November 26, 2009, 09:03:25 pm »
Ok so im currently doing a 1.9 swap and i have a question about the one fitting on the back of the engine. I ended up swapping the t3 turbo and manifold to the 1.9 and this fitting is different.
Sorry for the sh!tty celly pics and the noob questions.
Is there anything i can do to make the fitting off the 1.6 engine work? or can i use a rubber hose?
Also, There was something attached to the small stock turbo that i have no idea what it is...
Once again sorry for being a noob. Do i use it with my t3? or take it off.
And there are wiring connections at the other end for it.
Alright sorry for all the bad pics... Hopefully this makes a little sense, im also swapping the complete mk3 harness with the motor aswell as the dash.
The car
Thanks again! I just wanna finish this swap.
Reply #1November 26, 2009, 10:14:02 pm
GEE-BEE
  • 1604
Re: mk2 1.9 td swap. pics and questions
« Reply #1 on: November 26, 2009, 10:14:02 pm »
See the oil return drain thread for info on the drain..
You can get a adapter and hose from ebay as a kit..
Picture two is the wastegate control valve..
Gee-Bee
« Last Edit: November 26, 2009, 10:21:50 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2November 27, 2009, 05:59:49 am
brandon5
  • 88
« Reply #2 on: November 27, 2009, 05:59:49 am »
So do i need that wastegate if i have one on the manifold already? Is there any alternitive for the return line? Can someone give me a link to ebay?
Thanks 10000000
Reply #3November 27, 2009, 11:55:55 am
brandon5
  • 88
« Reply #3 on: November 27, 2009, 11:55:55 am »
Bumpppp i wanna get this swap movinnn
Reply #4November 27, 2009, 02:27:36 pm
« Reply #4 on: November 27, 2009, 02:27:36 pm »
You could get a 1.6TD oil pan, plug the hole in the block and use the stock 1.6TD oil return line.
Correct me if I am wrong but I don't think that the stock line would be long enough
The T3 already has it's own wastegate. What you have in the picture is useless to your swap
Reply #5November 27, 2009, 08:58:01 pm
brandon5
  • 88
« Reply #5 on: November 27, 2009, 08:58:01 pm »
Alright cool thanks for the reply. What would i do with the wiring and the tubing then? just plug it?
