Author Topic: freeze plugs, same in 1.6 and 1.9 ?  (Read 1905 times)
November 19, 2009, 03:38:14 pm
87octane
« on: November 19, 2009, 03:38:14 pm »
Does the 1.6 block heater that installs in the freeze plug hole fit the 1.9 exactly?
Was it ever an OEM part or always aftermarket?
Reply #1November 19, 2009, 04:11:02 pm
dokarex
  • 61
Re: freeze plugs, same in 1.6 and 1.9 ?
« Reply #1 on: November 19, 2009, 04:11:02 pm »
Yes they are the same block heater. I don't think they were factory installed but dealer installed in cold climates I think but am not sure.
1987 1.9TD Doka from Germany gasser DU tranny, fuel turned up, 1.6 LDA pin, boost at 15 psi,egt and boost gauges,stock diesel tach,air filter behind passenger tail light, IC to come
2005 Jetta Wagen TDI
B6200 Kubota Diesel
16ft Freestyle catermeran
16ft Sunray 85HP
