Author Topic: Bad head/headgasket?  (Read 3844 times)
November 16, 2009, 09:29:34 am
Manny
  • 2
« on: November 16, 2009, 09:29:34 am »
Hello, this is my first post here, I'm from sweden and have made myself a uniqe Golf mk1 diesel.
Here is a project thread about it: http://forums.vwvortex.com/zerothread?id=4638652
Engine is a 1,9 TD AAZ, the problem with it is that it's getting really hot under load, like when i do 60 mph or faster or push it hard.
The faster i drive, the hotter the car gets, but not as hot as it boils.
Radiator is flushed and thermostat is working (opens at 87 degrees celsius).
I my expansion tank i can see lot's of tiny bubbles. You can see for yourself here:
Bad headgasket vw TD?
Could it be a small crack in the head or a bad headgasket?
Reply #1November 16, 2009, 11:34:30 am
Re: Bad head/headgasket?
« Reply #1 on: November 16, 2009, 11:34:30 am »
How fast does the tank pressurize after starting it cold?
Just looked at your build.... :o, quite the rig haha and them lights probly about push you backwards lol
Reply #2November 17, 2009, 01:54:47 pm
  • 3468
    • McScrubbins Body Wash
« Reply #2 on: November 17, 2009, 01:54:47 pm »
How do you power 10kilowatts of light like that?
I've heard of large speakers (like a 1000+ watt sub system) killing a battery in minutes (with the car running...)
but you must have at least 1,000 watts of lights on there?!
Is this your left4dead, 28 days later, resident evil survival tank? :P
Reply #3November 17, 2009, 01:56:08 pm
  • 3468
« Reply #3 on: November 17, 2009, 01:56:08 pm »
oh, in response to your actual post...
are you POSITIVE it's not boiling?
Steam doesn't transfer heat.
Reply #4November 19, 2009, 12:56:05 pm
Manny
  • 2
« Reply #4 on: November 19, 2009, 12:56:05 pm »
it's not boiling. Not even when i open the cap when its hot.
The lights forward is actually 1005 watts, everythins is 1445watts. No problem at all to power.
Double batteries (one on the roofrack) and a 120 amp alternator.
A few clips of the lights.
http://www.youtube.com/user/mannynerd
