Author Topic: How embarassing...My delivery valve is showing  (Read 5060 times)
November 11, 2009, 08:09:53 pm
« on: November 11, 2009, 08:09:53 pm »
cracked one loose getting  my new Junkyard IDI pump out, and I can't find a torque spec.
anyone?
Reply #1November 13, 2009, 11:29:05 pm
Re: How embarassing...My delivery valve is showing
« Reply #1 on: November 13, 2009, 11:29:05 pm »
I've spent a few hours searching the internet, and I still cannot find how tight I need to get the Delivery valves  into the distributor head.
I see it has a copper washer that may need some work.
any help?
Reply #2November 13, 2009, 11:32:30 pm
rabbitman
  • 2788
« Reply #2 on: November 13, 2009, 11:32:30 pm »
IIRC the bentley says 18ft-lbs. Can't remember for sure though but it seems like it said 'if a delivery valve is leaking torque it down', my manual is at work or I'd check........
Reply #3November 13, 2009, 11:52:40 pm
« Reply #3 on: November 13, 2009, 11:52:40 pm »
"If at first you don't succeed"...
Reply #4November 14, 2009, 09:37:14 am
« Reply #4 on: November 14, 2009, 09:37:14 am »
The torque spec is in the mk3 bentley which I don't have with me right now.
Reply #5November 14, 2009, 12:03:43 pm
rabbitman
  • 2788
« Reply #5 on: November 14, 2009, 12:03:43 pm »
I think I recall when I first read it that it was the same as the injector lines.......and it said something weird like if it leaks tighten it some more ???
Reply #6November 14, 2009, 12:40:50 pm
  • 3255
    • My collection of HOWTOs
« Reply #6 on: November 14, 2009, 12:40:50 pm »
MK3 Bentley says 45 NM / 33 ft-lbs.
Reply #7November 14, 2009, 03:34:25 pm
« Reply #7 on: November 14, 2009, 03:34:25 pm »
I suppose copper seal washers are not the most precision parts, so specifying a torque that mashes it enough not to leak can be tricky.
I think it is the hardest one to reach while installed on the car too, but I'll start easy on it, and hope for the best.
Reply #8November 14, 2009, 03:59:39 pm
« Reply #8 on: November 14, 2009, 03:59:39 pm »
Don't snap it off. Broken delivery valve holders are almost impossible to get out of the head. If it feels like it's breaking, it probably is.
