Author Topic: How to change MK1 diesel motor mounting rubber from frame  (Read 2717 times)
November 08, 2009, 07:33:09 pm
Familydiesel
  • 154
« on: November 08, 2009, 07:33:09 pm »
Does anyone know a sure and/or doable way of removing (and installing a new) the motor mounting rubber (cylinder with rubber mounting) from the front motor mount housing on Mk1 diesel?  I tried to punch it out with a punch, but it didn't budge.  Does it need to be pressed out?  I need to change the rear transmission mount as well, so the same principles would apply to both.
I would appreciate your counsel.
Greg ::)
1980 Diesel td pickup, Love that Diesel!
Reply #1November 08, 2009, 07:56:12 pm
macka
  • 957
Re: How to change MK1 diesel motor mounting rubber from frame
« Reply #1 on: November 08, 2009, 07:56:12 pm »
use a C clamp and a large socket. Put the socket on the foot of the C clamp and then twist it out. You need the socket to fit around the rubber mount, but not bigger then the steel housing.
Quote from: Vincent Walden
Reply #2November 08, 2009, 08:02:51 pm
Familydiesel
  • 154
« Reply #2 on: November 08, 2009, 08:02:51 pm »
Would I need two sockets:  one for the housing, and another slightly smaller one to fit the rubber mount housing?
Reply #3November 08, 2009, 08:08:49 pm
macka
  • 957
« Reply #3 on: November 08, 2009, 08:08:49 pm »
no just one that fits on the metal housing, if you have a smaller clamp you may need one to push the bushing through.
Reply #4November 08, 2009, 08:11:26 pm
Familydiesel
  • 154
« Reply #4 on: November 08, 2009, 08:11:26 pm »
Ok, thanks.  Cool!
Greg
Reply #5November 08, 2009, 08:16:29 pm
macka
  • 957
« Reply #5 on: November 08, 2009, 08:16:29 pm »
oh and when inserting the new bush, use some WD40 and punch it in with the clamp real quick.
Reply #6November 08, 2009, 08:23:38 pm
Familydiesel
  • 154
« Reply #6 on: November 08, 2009, 08:23:38 pm »
Thanks, I was wondering if it would be helpful to lube up the new mount before installing it.  When I get another bracket, I will try what you say.  I don't have large enough sockets, so I'll need to find something comperable, or make something to work.
Reply #7November 09, 2009, 09:41:13 am
macka
  • 957
« Reply #7 on: November 09, 2009, 09:41:13 am »
If you have an air hammer, it will punch it out pretty good. Just don't be surprised if the bush frags on you.
Reply #8November 09, 2009, 10:59:28 am
Familydiesel
  • 154
« Reply #8 on: November 09, 2009, 10:59:28 am »
Yeah, it might fragment, I may just cut it with a sawsallthen press it back in with the socket and c clamp. Now I just need a bracket!
Thanks
