Author Topic: WTB: Garret T3 TA0304 Turbo  (Read 4898 times)
November 04, 2009, 09:21:58 am
rabbitpower
  • 45
« on: November 04, 2009, 09:21:58 am »
I am attempting my first rebuild of a turbo. I have the turbo apart, and everything looks pretty good. The engine is an 86 1.6L TD out of a Jetta. I am looking for another turbo in case things don't go so well with the rebuild :(
Reply #1November 04, 2009, 09:46:51 am
GEE-BEE
  • 1604
Re: WTB: Garret T3 TA0304 Turbo
« Reply #1 on: November 04, 2009, 09:46:51 am »
I have a k14 and exhaust manifold in perfect condition if you cant find something..
I have the Oil drain also...
Gee-Bee
[email protected]
« Last Edit: November 05, 2009, 08:34:02 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2November 04, 2009, 08:05:46 pm
Sam Johnson
  • 55
« Reply #2 on: November 04, 2009, 08:05:46 pm »
Gee-Bee,
Do you know if the K14 will replace the T3 directly?  If not what has to be done to replace the T3 that I have on my 1.9 TD AAZ with a K14??
Regards,  Sam
Tucson, AZ
Reply #3November 05, 2009, 12:27:17 pm
« Reply #3 on: November 05, 2009, 12:27:17 pm »
Oil drains are different, other then that it should be the same going from a T3 to a K14
I have a T3 but it needs to be rebuilt...
Reply #4November 06, 2009, 05:55:12 am
rabbitpower
  • 45
« Reply #4 on: November 06, 2009, 05:55:12 am »
Does anyone know if I can replace the wastegate on the T3?. It's an internal one. I don't know if it is bad or not yet, but if it ends up being bad are there any options?
Reply #5December 06, 2009, 03:51:01 am
rabbitpower
  • 45
« Reply #5 on: December 06, 2009, 03:51:01 am »
Still lookin for a good T3.
Reply #6December 06, 2009, 06:17:24 am
ilikevwdiesel
  • 1202
    • Erupt into a BEVRAGE this summer with Glug!
« Reply #6 on: December 06, 2009, 06:17:24 am »
I have a turbo off an 84 Jetta. It says air research on it, not Garret. What kind of turbo is that?  ???
Look, if corn and kudzu fall in love and have a baby in a lab under the supervision of scientists working in my employ, WHO AM I TO STOP THAT other than the CEO responsible for stopping it???
My Bio
Reply #7December 06, 2009, 07:24:10 am
GEE-BEE
  • 1604
« Reply #7 on: December 06, 2009, 07:24:10 am »
IT'S THE SAME..
Giles Pump OHC
MK1 JETTA DASH
Reply #8December 06, 2009, 09:12:53 am
ilikevwdiesel
  • 1202
« Reply #8 on: December 06, 2009, 09:12:53 am »
yeah I just looked at it, it doesn't say anything on it actually. I think it is a T3. It's in good shape no shaft play or damage to the fans. It does have one stud broken off on the outlet side. If anyone wants it I'll take 125.00 plus a USPS flat rate box. Comes with the return line.
My Bio
