Author Topic: 2001 Golf TDI GL / GTI lookalike for sale  (Read 4154 times)
October 08, 2005, 04:39:12 am
therabbittree
  • 299
« on: October 08, 2005, 04:39:12 am »
I we have decided to sell our 2001 Golf GL TDI. We have a B4 Passat Wagon already and a few other TDI projects going on..
any how we bought the car NEW in 2001. I removed the crankcase vent as soon as it was home. There is no egr on the car now either, it has a espilion device, and egr dialed back with vag com. It is the dark green color with Blacked out Ecodes in the front , clear side corners, GTI tinted Tails, I have 2 sets of rims - on factory 15" steels with snows (tires are about 25%), and a set of 16" monteral IIs with good tires, full 1.8T GTI suspension swap, new front wheel bearings, new timing belt kit with 100k belt - improved 2003 and later idler, and new water pump, has factory mud flaps, and bunch of touched up paint chips from commuting. The interior has full black leather GTI interior with arm rest and heated seats. ( the heated switch is not hooked up but I hope to have it hooked up for the new owner), full set of Autometer Ultralight guages EGT, Boost, and Voltmeter, mounted in stock cubby hole with aftermarket guage panel. I have full set of GTI pedals and dead pedal with the stainess trim i have not installed yet. The engine has a upsolute chip, CCV mod, No egr, DD Race pipe, EGT pre turbo, EGR Dialed back, Epsillion device, Kerma power plus 216s nozzles( I am removing them and putting stock nozzles back need the big nozzles for my project), Lightened G60 Flywheel / VR6 Clutch, NEW MAF, New Winshield, mufflerectomy, fumota drain valve setup, diesel geek larger oil cooler, and Delvac 1 oil for whole life of vehicle. I have done all maintenance and have records. we keep records of all Fuel stops since new (we are at 200 now), 129k miles. My wife commuted 100 miles a day to work for 3 years and i have used it the last year about the same distance for my work commute. We haven't used it much the last 6 months as I transfered closer to home, with company vehicle. We have taken it off the road to save $ and to put another vehicle on soon. So the mileage is all highway. It has also has the euro factory metal skid plate, I coated it with plastic bed liner. We are asking $9,500. Firm.
Thanks
Deo
[email protected]
(845)223-3342
Reply #1October 13, 2005, 02:05:31 pm
therabbittree
  • 299
« Reply #1 on: October 13, 2005, 02:05:31 pm »
deposit being held, sale pending
thanks
Deo
