For Sale/Looking For
Parts for Sale/Wanted
WTB: Fuel tank, Mk2 or Mk3 Golf/Jetta diesel—PNW
Topic: WTB: Fuel tank, Mk2 or Mk3 Golf/Jetta diesel—PNW (Read 4833 times)
October 28, 2009, 06:25:22 am
clyde
Newbie
October 28, 2009, 06:25:22 am »
Want to put a diesel in a 86 Golf gasser, so need a tank.
Or an effective way to remove the restriction from the filler neck of the gas tank!
Last Edit: October 28, 2009, 06:51:37 am by clyde
October 28, 2009, 06:46:19 am
myke_w
Re: WTB: Fuel tank, Mk2 or Mk3 Golf/Jetta diesel—PNW
October 28, 2009, 06:46:19 am »
Bump for you Kent
Someone will help you out here.
October 28, 2009, 06:53:44 am
clyde
Newbie
October 28, 2009, 06:53:44 am »
"Upgraded oil pumps?" For ALH only?
How about for 1Z/AHU?
October 28, 2009, 06:58:41 am
myke_w
October 28, 2009, 06:58:41 am »
Just stock for AHU/1Z sorry.
Then only upgraded pump I carry is for 1.6 engines.
October 28, 2009, 09:43:29 am
husseycm
Newbie
October 28, 2009, 09:43:29 am »
I have a tank from a 98 jetta tdi, its in NY though.
October 28, 2009, 11:14:52 am
October 28, 2009, 11:14:52 am »
I have a gasser tank in my '91 Golf.
I heated a piece of 3/4" metal pipe with a propane torch and stuck it in the hole.
Melted the plastic hole until it was big enough,.. the metal flapper pulled right out after that.
October 29, 2009, 06:44:29 am
Spulen81
October 29, 2009, 06:44:29 am »
I did exactly the the same thing on my '91. Very easy and very little mess. I have a diesel tank sender from my '86 diesel if you need one.
'86 4Runner TDI SOLD
'91 GTI - TDI converted
October 30, 2009, 06:23:00 am
clyde
Newbie
October 30, 2009, 06:23:00 am »
Interesting! A hot pipe—gimme that torch!
But why would the fuel level sender be any different for diesel than for gas? The pickup lacks the pump and the screen is coarser for diesel, but I don't see why the fuel level sender would be different… Clue me in!
October 30, 2009, 09:28:13 am
Spulen81
October 30, 2009, 09:28:13 am »
I consider the sender the whole unit including the fuel level sensor. The whole lower section is different but you can just replace the pum with a tube.
October 30, 2009, 07:12:20 pm
October 30, 2009, 07:12:20 pm »
I've always wondered how well the intank pump would work as a helper pump in our diesels.
