Author Topic: WTB: Fuel tank, Mk2 or Mk3 Golf/Jetta diesel—PNW  (Read 4834 times)
October 28, 2009, 06:25:22 am
clyde
  • 10
« on: October 28, 2009, 06:25:22 am »
Want to put a diesel in a 86 Golf gasser, so need a tank.
Or an effective way to remove the restriction from the filler neck of the gas tank!
« Last Edit: October 28, 2009, 06:51:37 am by clyde »
Reply #1October 28, 2009, 06:46:19 am
myke_w
  • 1099
Re: WTB: Fuel tank, Mk2 or Mk3 Golf/Jetta diesel—PNW
« Reply #1 on: October 28, 2009, 06:46:19 am »
Bump for you Kent
Someone will help you out here.
Reply #2October 28, 2009, 06:53:44 am
clyde
  • 10
« Reply #2 on: October 28, 2009, 06:53:44 am »
"Upgraded oil pumps?" For ALH only?
How about for 1Z/AHU?
Reply #3October 28, 2009, 06:58:41 am
myke_w
  • 1099
« Reply #3 on: October 28, 2009, 06:58:41 am »
Just stock for AHU/1Z sorry.
Then only upgraded pump I carry is for 1.6 engines.
Reply #4October 28, 2009, 09:43:29 am
husseycm
  • 5
« Reply #4 on: October 28, 2009, 09:43:29 am »
I have a tank from a 98 jetta tdi, its in NY though.
Reply #5October 28, 2009, 11:14:52 am
  • 2932
« Reply #5 on: October 28, 2009, 11:14:52 am »
I have a gasser tank in my '91 Golf.
 I heated a piece of 3/4" metal pipe with a propane torch and stuck it in the hole.
 Melted the plastic hole until it was big enough,.. the metal flapper pulled right out after that.
Reply #6October 29, 2009, 06:44:29 am
Spulen81
  • 103
« Reply #6 on: October 29, 2009, 06:44:29 am »
I did exactly the the same thing on my '91.  Very easy and very little mess.  I have a diesel tank sender from my '86 diesel if you need one.
'86 4Runner TDI SOLD
'91 GTI - TDI converted
Reply #7October 30, 2009, 06:23:00 am
clyde
  • 10
« Reply #7 on: October 30, 2009, 06:23:00 am »
Interesting! A hot pipe—gimme that torch!
But why would the fuel level sender be any different for diesel than for gas? The pickup lacks the pump and the screen is coarser for diesel, but I don't see why the fuel level sender would be different… Clue me in!
Reply #8October 30, 2009, 09:28:13 am
Spulen81
  • 103
« Reply #8 on: October 30, 2009, 09:28:13 am »
I consider the sender the whole unit including the fuel level sensor. The whole lower section is different but you can just replace the pum with a tube.
Reply #9October 30, 2009, 07:12:20 pm
  • 2932
« Reply #9 on: October 30, 2009, 07:12:20 pm »
I've always wondered how well the intank pump would work as a helper pump in our diesels.
