Author Topic: Diesel-friendly transmissions?  (Read 13687 times)
October 26, 2009, 03:45:28 pm
rallydiesel
  • 1880
« on: October 26, 2009, 03:45:28 pm »
I am pretty much a noob when it comes to my VW transmission knowledge. Could someone educate me on the different types of trannies and their compatibility with vw diesel engines? I know about the 020. I am interested in the stronger transmissions though.
Is the 02M the only 6-speed? Is the 02A the basic mk3 transmission? Is the 02J the mk4-5 tranny? What trannies will mate to the early blocks (1.6/1.9 IDI, AHU, 1Z)?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #1October 26, 2009, 03:58:48 pm
rallydiesel
  • 1880
Re: Diesel-friendly transmissions?
« Reply #1 on: October 26, 2009, 03:58:48 pm »
What's the tallest geared transmission? Cuz this 020 4S sucks. 100km/h in 5th at 1300 egt and 6 psi is not fun.
Reply #2October 26, 2009, 04:17:07 pm
rallydiesel
  • 1880
« Reply #2 on: October 26, 2009, 04:17:07 pm »
Also, what types will mount into a mk2/3 without changes to the mounts themselves?
Reply #3October 26, 2009, 06:25:03 pm
Spulen81
  • 103
« Reply #3 on: October 26, 2009, 06:25:03 pm »
The tallest is the CTN code O2A from a A3/B4 TDI.  Its got a 3.15 r&p and a .75 5th.  You can bolt up any O2A or O2J in a MK2 with stock MK2 mounts.  You just need to make sure the O2J (mk4) has 100mm flanges, which any TDI trans will have.  If not the flanges just bolt on and are easy to swap. You'll need 100mm axles too ofcourse.
The CTN is the best with MK2 tire sizes IMO.
'86 4Runner TDI SOLD
'91 GTI - TDI converted
Reply #4October 26, 2009, 08:06:15 pm
rallydiesel
  • 1880
« Reply #4 on: October 26, 2009, 08:06:15 pm »
Awesome, thanks. So with an 02a, could I run a VR6 clutch with a G60 flywheel (or oem AHU/1Z flywheel)?
Reply #5October 27, 2009, 05:59:17 am
Spulen81
  • 103
« Reply #5 on: October 27, 2009, 05:59:17 am »
Yup, you can run a VR6 clutch with the stock G60/1Z/AHU flywheel.  I have this setup in my car right now.  Watch out for the aftermarket flywheels, they usually come without a TDC mark on them and I've heard about alot of quality issues.
Reply #6October 27, 2009, 06:55:04 am
G60ING
  • 170
    Corrado TDI
    • My VW Projects
« Reply #6 on: October 27, 2009, 06:55:04 am »
I'm using a CTN O2A in my corrado and it really is the best due to its ratios. Mk4 people even want its final drive. I've also tried the O2J transmissions but the 3.1 R&P is the best combo for a mk1/mk2/Mk3 wheel and tire size.
Reply #7December 04, 2009, 08:30:08 am
scottmandu
  • 20
    • http://www.advancedautomotion.com
« Reply #7 on: December 04, 2009, 08:30:08 am »
The tallest is the CTN code O2A from a A3/B4 TDI.  Its got a 3.15 r&p and a .75 5th.  You can bolt up any O2A or O2J in a MK2 with stock MK2 mounts.  You just need to make sure the O2J (mk4) has 100mm flanges, which any TDI trans will have.  If not the flanges just bolt on and are easy to swap. You'll need 100mm axles too of course.
You can also change the 5th gear easily with ratios from .700 to .622 for nice low cruising RPMS.
Also the ring and pinion is a 3.16 (3.157894737) ratio.
Reply #8December 09, 2009, 12:38:50 am
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
« Reply #8 on: December 09, 2009, 12:38:50 am »
Where can someone get one of these?  I have been looking for this information for my build.  Good information, thanks. :D
Reply #9December 10, 2009, 08:30:43 am
scottmandu
  • 20
« Reply #9 on: December 10, 2009, 08:30:43 am »
http://www.advancedautomotion.com/index.php?cPath=69_137
We are also working on a drop in 6 speed to directly replace the 02J/02A 5 speed.
Reply #10December 14, 2009, 04:06:55 am
scottmandu
  • 20
« Reply #10 on: December 14, 2009, 04:06:55 am »
You might want to check this thread out.
http://forums.tdiclub.com/showthread.php?t=266693
Reply #11December 14, 2009, 06:24:40 am
NintendoKD
  • 931
    • myspace page
« Reply #11 on: December 14, 2009, 06:24:40 am »
says mkIV/V, will this work for MKI's?  not everyone has one of those new deals dontchaknow ::)
Reply #12December 17, 2009, 07:21:43 am
« Reply #12 on: December 17, 2009, 07:21:43 am »
With a bit of custom fab, it will.
There are ready-made mounts to fit an 02A/J in an A1 chassis.  Still have to deal with axles, shifter, etc... but that's all been covered thousands of times.
Reply #13December 17, 2009, 07:29:30 am
« Reply #13 on: December 17, 2009, 07:29:30 am »
For a drop-in 020 tranny, look for an ACN (or AON, ASF, or ACL, all the same) It has a 3.67 final, and a .75 5th.  Tallest 020 there is.
1st:  3.45
2nd: 1.94
3rd:  1.37
4th:  1.03
5th:  .75
I have this box in my Wife's car, the drop from 1st to 2nd is a bit long, but 2-3-4 is really nice in town, and it purrs along nicely in 5th on the open road.  1st is too short to build boost (with a big turbo, hehe) and 2nd is too steep to launch from, but I didn't build the car to drag race, and I don't think my Wife is going to do too much street racing.  :P
Reply #14January 03, 2010, 09:26:15 am
« Reply #14 on: January 03, 2010, 09:26:15 am »
ive got the ACN in my car, i like the lay out of 1-4 gears, but the jump from 4th to fifth is just massive. the first 3 gears are fine to build boost in my experiences, worked well so far. i build boost just fine in first gear, then really build the boost in 2nd. i hate to chime in and negate most of what you just said, but it works just fine for me. builds boost faster than my 4 speed, thats for sure.
