Author Topic: 98 Cummins dorkin out  (Read 4995 times)
October 11, 2009, 08:37:11 pm
FoXBoXRaCiNG
  • 92
« on: October 11, 2009, 08:37:11 pm »
A buddies truck: 200ish kms, new IP, new fuel tank, added a lift pump to a stock location, no fuel tank vacuuming, free flowing catless stock exhaust, clean air filter, fresh fuel filter, runs and idles fine...
After a couple hundred meters it starts to dork and you lose all power like it's getting the fuel cut off, the more fuel pedal the worse it gets?!?!? All that's listed above has been done try ing to resolve the issue...
Any input anyone?
My cat has A.D.D :(
Reply #1October 12, 2009, 05:58:50 am
macka
  • 957
Re: 98 Cummins dorkin out
« Reply #1 on: October 12, 2009, 05:58:50 am »
is the lift pump restricting flow? Some of the junkie lift pumps can't keep up with the cummins pressure needs.
Quote from: Vincent Walden
I do know that I drive torque,  while listening to my friends prattle on about horsepower.
Reply #2October 13, 2009, 01:31:20 pm
rabbitman
  • 2788
« Reply #2 on: October 13, 2009, 01:31:20 pm »
Definitely sounds like it's not getting enough fuel
Reply #3October 14, 2009, 05:51:19 pm
dieselweasel
  • 312
« Reply #3 on: October 14, 2009, 05:51:19 pm »
Yes check the fuel pressure.
Reply #4October 16, 2009, 02:52:56 pm
« Reply #4 on: October 16, 2009, 02:52:56 pm »
check the fuel suction hose from the tank to see if there are any restrictions. also check all the banjo bolts for cloggs. i had a clogged banjo bolt once and my car would starve for fuel bad.
Reply #5October 20, 2009, 07:46:11 am
hippiekiller
  • 73
« Reply #5 on: October 20, 2009, 07:46:11 am »
If its a 24V its probably a lift pump, definitely check fuel filter though anyway.....could be gelled allready?
95 jetta, 2"lift
92 dodge diesel too much to list
Reply #6October 22, 2009, 03:47:02 am
topless96
  • 58
« Reply #6 on: October 22, 2009, 03:47:02 am »
My 2001 Cummins will throw a code for behavior like that. Did you read the codes and does it show a CEL.
