Author Topic: Leak from injection pump! How to fix?  (Read 5088 times)
October 01, 2009, 03:28:37 pm
The Mad Hatter
  • 85
« on: October 01, 2009, 03:28:37 pm »
Hello all!  Once again the VW is leaking.  I'm not sure what this valve is, but it leaks from behind the nut.  I tried jacking it down, but that made the leak worse.  What is this valve and how can i fix the leak?  Is there a gasket behind it?  Picture below of the valve (shiny valve in middle with screw).  Thanks for any help!  I gotta get this back on the road asap!
Reply #1October 02, 2009, 07:50:08 am
The Mad Hatter
  • 85
Re: Leak from injection pump! How to fix?
« Reply #1 on: October 02, 2009, 07:50:08 am »
Yes, that's exactly what i'm talking about.  Sorry, i don't know much about these things!  Thanks for the info, i'm guessing that o-ring is gone bad.
Reply #2October 06, 2009, 02:03:24 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #2 on: October 06, 2009, 02:03:24 pm »
Just in case you didn't count right, have something to suffocate the engine in case it runs away. ;D
Reply #3October 06, 2009, 02:57:39 pm
« Reply #3 on: October 06, 2009, 02:57:39 pm »
Do not use your hand!!    :-X
Reply #4October 06, 2009, 04:06:29 pm
truckinwagen
  • 1895
« Reply #4 on: October 06, 2009, 04:06:29 pm »
surely turning the ignition off would do the same?
as long as it is just injecting too much fuel(because the screw was turned in too far) and not actually running away on oil
-Owen
83 Opel Kadett Diesel
Reply #5October 07, 2009, 02:40:04 pm
smutts
  • 720
« Reply #5 on: October 07, 2009, 02:40:04 pm »
Ah! Right you are, where is the embarrassed smiley? ;D
Reply #6October 07, 2009, 03:33:34 pm
« Reply #6 on: October 07, 2009, 03:33:34 pm »
Reply #7October 07, 2009, 08:13:37 pm
SolarSteve
  • 264
« Reply #7 on: October 07, 2009, 08:13:37 pm »
What, exactly, will happen to your hand IF you did try to suffocate the engine with it?
Has anyone tried this before or is it just a "I don't think it would feel too good" kind of thing?!
Steve
91 Jetta 1.6 N/A
Reply #8October 08, 2009, 07:34:13 pm
maxfax
  • 2126
« Reply #8 on: October 08, 2009, 07:34:13 pm »
Granted a vw probably doesn;t have quite the suction, but it wasn;t pretty what a 371 jimmy does to the yellow pages...
Reply #9October 08, 2009, 08:43:30 pm
« Reply #9 on: October 08, 2009, 08:43:30 pm »
I heard of a guy that tried to kill a ran away detroit diesel by sitting on the intake, killed 'im instead........ :o
Reply #10October 09, 2009, 07:47:38 am
macka
  • 957
« Reply #10 on: October 09, 2009, 07:47:38 am »
before you yank the bolt, mark the threads with paint. Then you only have to twist it down to where the paint starts and fine tune it from there.  ;)
Quote from: Vincent Walden
