General Information
Troubleshooting
mk4 jetta door switch
Topic: mk4 jetta door switch (Read 7128 times)
September 23, 2009, 09:43:40 am
mr.woods
September 23, 2009, 09:43:40 am »
Were is the door switch on a 99.5 jetta and how does it work? All the doors work but the drivers
. I know the plunger type, and the new slide type, but didn't see anything right away by looking at it. I didn't get my repair manual yet.
1.9 AAZ backed by a toyota tranny and dual cases, going into a rock crawler
September 23, 2009, 10:19:23 am
mr.woods
Re: mk4 jetta door switch
September 23, 2009, 10:19:23 am »
At the door latch correct? Just tried freeing it up, looks like I'll be taking the door apart.
September 27, 2009, 03:03:34 am
sawedoffgolf
September 27, 2009, 03:03:34 am »
what issues are you having with your door locks? im having some issues with mine but its nothing major(minor wiring issues)
i've taken alook at this
http://forums.vwvortex.com/zerothread?id=1542461
as helpful that it is it doesnt cover my issue, maybe it will help you out.
September 27, 2009, 07:31:24 am
September 27, 2009, 07:31:24 am »
This is a very very very very very common MK4 problem... did I mention it's very common?!
On an MK4 the switch is built into the door latch itself within the door and seems to not last very well. Because it's inside the door it's a bit of a pain to get to but the repair is fairly staightforward and is known as the "3 dollar fix":
http://forums.tdiclub.com/showthread.php?t=77648
The danger of having a broken driver door switch is that if you unlock the car with the remote and then let yourself in the car via the driver's door the car won't know you've opened the door and will auto-lock itself in a couple of minutes. If you've gone back in the house to get something the keys are now locked in the car... BTDT.
September 27, 2009, 11:47:14 am
mr.woods
September 27, 2009, 11:47:14 am »
I noticed the auto lock already
. But i didn't seem to have the auto lock working untill I tried to reprogram the (key in door) window feature to work again. I did get the switch to work if I pull on the inside handle all the way, after I cleaned it out with carb cleaner. So I hope I can just lube it up and it might have a chance to work better. Thanks for the info!
General Information
Troubleshooting
