Author Topic: Stock TD and GTD injector tip sizes?  (Read 3829 times)
September 22, 2009, 09:10:48 pm
vwjunkie53
  • 98
    • The Volvo diesel forum
« on: September 22, 2009, 09:10:48 pm »
I was reading inthe venders section and came across a post made by Giles... He listed the stock injectors as DNOSD293 for TD and DNOSD274 as GTD?  I thought the GTD nozzles were considered the higher performance nozzles...  They are smaller?  I'm just trying to find out for sure if that is the stock size, as I have access to them at work and would love to install them in my D24T.  The us spec D24Ts had a 193 injector tip. The 293 was only found on the D24Tic in Europe...
Thanks for any help.
Jason
1984 Volvo 760 GLE,  "built" D24T w/ARP studs, MLS head gasket, ported/polished head, 3 angle valve job, NA cam, 56mm T3/T4, NA manifold, FMIC w/ 3" alum piping, 3" turbo back, detailed in CAT yellow. T-5 manual swapped w/ Clutchnet 6-puck.  Best of 16.07@86mph with orig. worn out engine.
Reply #1September 22, 2009, 09:16:42 pm
Re: Stock TD and GTD injector tip sizes?
« Reply #1 on: September 22, 2009, 09:16:42 pm »
The last three digits of the Bosh part number aren't particularly related to size... so it's hard to tell which is "bigger".  A definite part number cross-reference is a bit of a holy grail in these parts.
Generally on an IDI the nozzle size not actually a performance limiter... at least until most every other performance issue has been addressed... exhaust, injector pump mods, etc.  Stock injectors, whatever part number, are generally seen to be good for several hundred horsepower.
Now on a TDI nozzle size *is* a handy upgrade. ;D
« Last Edit: September 22, 2009, 09:19:11 pm by Vincent Waldon »
Reply #2September 23, 2009, 04:06:58 am
anto
« Reply #2 on: September 23, 2009, 04:06:58 am »
See below, particularly Mark the miser's post for what the injector no's mean;
http://www.vwdiesel.net/forum/index.php?topic=21324.0
Also here is a list of bosch part no's including nozzle codes, tobera is a nozzle;
http://www.recordparts.com.ar/catalogos/BOSCH_DIESEL_CATALOGO_15-02-07.pdf
Reply #3September 23, 2009, 04:24:43 am
vwjunkie53
  • 98
« Reply #3 on: September 23, 2009, 04:24:43 am »
Interesting, thanks for the links... I had been told the last numbers were related to the tip size.  Ok then, what is a good upgrade for more fuel flow potential?
Jason
Reply #4September 23, 2009, 07:23:34 am
« Reply #4 on: September 23, 2009, 07:23:34 am »
dude, the injectors are gonna be fine no matter what you run. you can get probably right around 300 horses out of the stock injectors if you could keep the head bolted down.
Reply #5September 23, 2009, 04:00:13 pm
Mark(The Miser)UK
  • 1557
« Reply #5 on: September 23, 2009, 04:00:13 pm »
Great link Anto. Not seen the numbers linked to the vehicles  before except for a few Japanese cars.
The link to me contains a slight ambiguity. The 'S' tells us according to Bosch that it's the 17mm nozzle holder. I'm sure I've seen references to the 6mm pintle needle that it contains... Same difference really :-[
 For those that have eyes watering at all the  pages in non English, scroll down to page 102ish for the nozzles :o
« Last Edit: September 23, 2009, 04:02:48 pm by Mark(The Miser)UK »
Mark-The-Miser-UK
Reply #6September 23, 2009, 06:28:16 pm
vwjunkie53
  • 98
« Reply #6 on: September 23, 2009, 06:28:16 pm »
Can I change the question a little then?  If I'm just going to replace the injectors, would you use the 84 back injectors or 85 up.  The Importer we buy from at work lists two different part numbers for the rebuilt injectors for those years.  I'm guessing the 85 and newer injectors would have the newer revised tip? If the numbers just increased as they made different changes or improvements, I'm thinking the 85 up injectors would be the way to go.  They are Bosch reman, but there is no listing with them that lists the p.n. of the nozzle itself.
Jason
Reply #7September 24, 2009, 06:43:36 am
anto
« Reply #7 on: September 24, 2009, 06:43:36 am »
Mark - can you take a look at my "injector no's" thread again as i added another question after you added your post on what the no's stood for.
