Author Topic: pump removal and mods  (Read 2281 times)
September 04, 2009, 12:43:39 pm
carrizog60
  • 978
« on: September 04, 2009, 12:43:39 pm »
hello
i am swapping the gtd pump to the 1.9 ecodisel passat...
how do i remove the pump?precautions?
also with the pump removed should i swap a 10mm head i have and do the governor mod of do this after?
would the 10mm head work ok with the 1.6 camplate.
the head i have only got plunger,springs ans head,no delivery valves.
its ok to use the 1.6 or should i use the 1.9ecodiesel ones?
Portugal
Reply #1September 04, 2009, 12:56:21 pm
gigaz2
  • 626
Re: pump removal and mods
« Reply #1 on: September 04, 2009, 12:56:21 pm »
1.9 are different length, every cam works with every plunger, if the correct shims are used, "HEY" has a nice how-to do it properly
I have two sets of delivery valves if you need them, 1.6 and 1.9
Reply #2September 04, 2009, 02:46:14 pm
carrizog60
  • 978
« Reply #2 on: September 04, 2009, 02:46:14 pm »
i also have those, i dont have the ones that came on the 10mm head...what to use?
what is different lenght?do you have the link for that how to?
Portugal
Reply #3September 04, 2009, 07:52:54 pm
gigaz2
  • 626
« Reply #3 on: September 04, 2009, 07:52:54 pm »
here: http://www.vwdiesel.net/forum/index.php?topic=5926.0
use the 1.6 delivery valves, or the 1.9, but not the tdi ones,as they have a different design
