Author Topic: Gas to Diesel tach question  (Read 3019 times)
August 29, 2009, 05:13:05 pm
topless96
  • 58
« on: August 29, 2009, 05:13:05 pm »
 Anyone know which wires to hook up the tach in a 1995 Vw cabrio? I put in a 1.6 TD from an 84 rabbit and have the W terminal on the alt. did it get its signal from the distributor on the gasser? if so there was 3 wires going to the distributor.
 Also having trouble with the spedo. Plugged the sensor from the 020 tranny and no speed indicated. Why did they go away from cables??? Any help greatly appreciated. I hate wires.
Reply #1August 30, 2009, 05:19:08 am
topless96
  • 58
Re: Gas to Diesel tach question
« Reply #1 on: August 30, 2009, 05:19:08 am »
Anyone?
Reply #2August 30, 2009, 06:59:49 am
dieseltech
  • 129
    • http://www.geocities.com/dean16v/Page_One.html
« Reply #2 on: August 30, 2009, 06:59:49 am »
Sherman,CT   ehy,   well your not far from me in poughkeepsie, i just converted a b3 passat wagon from 2.0 16v to 1.6td and have all the original gas engine cluster working including electric fuel pump, you should stop by and get some ideas, i have dealt with all these issues many times,
86 td jetta power everything dd (update off the road for major resto).  97tdi bare bones, DD
and a private junkyard of various other vw/audi/bmw/peugeot/volvo/toyota diesels!!!
Cummins has the worlds record for being the most efficient engine ever!!!!!
for converting fuel into noise!
Reply #3August 30, 2009, 08:53:35 am
carrizog60
  • 978
« Reply #3 on: August 30, 2009, 08:53:35 am »
could help here for others...
im also on that boat but i need a tach(my ecodiesel passat doesent have one) but td tachs are hard to find here...
gas tach are comon on ebay.de but i need to know if they can be made to work properly...
Portugal
Reply #4August 30, 2009, 02:33:21 pm
92EcoDiesel Jetta
« Reply #4 on: August 30, 2009, 02:33:21 pm »
There's an excellent document online with pinouts for CE2 cluster. I don't have the URL but if you search "central electric 2" and "central electric 2 cluster" I think you will find it. It's lists all the pinouts on the cluster and fuse block and with that info you can figure things out.
I am putting a gasser CE2 cluster (with tach) from some 85-92 Jetta or Golf that I picked up for $5 locally into my 92 Ecodiesel. I still have some more work to do to finish the project, hopefully in the next few weeks.
Reply #5August 30, 2009, 02:38:58 pm
92EcoDiesel Jetta
« Reply #5 on: August 30, 2009, 02:38:58 pm »
I just looked at my hard copy of the CE2 cluster doc and the tach signal is on T28/10. that means pin 10 of the 28 pin connector on the cluster. You also need ground which is T28/3.
Reply #6August 30, 2009, 05:03:19 pm
topless96
  • 58
« Reply #6 on: August 30, 2009, 05:03:19 pm »
Diesel tech will try to stop by, only 30 mins away. Got 96 Jetta parts if you need any. Junking the car and it has great sheetmetal, interior and more. Motor and tranny is out but also have 2L Gasser that runs excellent and an auto tranny cheep if needed.
Reply #7August 31, 2009, 07:33:36 am
92EcoDiesel Jetta
« Reply #7 on: August 31, 2009, 07:33:36 am »
Hey topless96, what ever happened to the wheels and tires that you wanted to sell cheap? Never heard back from you. Did you take some pics?
Reply #8August 31, 2009, 05:29:44 pm
topless96
  • 58
« Reply #8 on: August 31, 2009, 05:29:44 pm »
No pictures yet but I gave a phone number to call me? Never heard from you. Just had daughters grad party and had to hide everything from inlaws
« Last Edit: August 31, 2009, 05:31:24 pm by topless96 »
Reply #9August 31, 2009, 07:46:32 pm
92EcoDiesel Jetta
« Reply #9 on: August 31, 2009, 07:46:32 pm »
I just checked my PM to be sure. You did not send a phone # nor was there talk of calling .
Reply #10September 01, 2009, 05:42:07 pm
topless96
  • 58
« Reply #10 on: September 01, 2009, 05:42:07 pm »
you are right, I sent the PM to another guy about the gauges I had in the Jetta will PM #
