Author Topic: Intermediate shaft bearings. Are they the same as IDI and where to get them!  (Read 7335 times)
August 29, 2009, 07:11:49 am
ryanp
  • 269
Hi,
I'm building up my 1Z M-tdi project, i've drained the oil and removed the cambelt. Looking at the oil pump pulley it has a little play in and out, do i need to swap the bearings?
Should i clean the shaft up like people do with the IDI's?
Where can i get the bearings, I know baxter was struggling a few years ago!
Thanks
Ryan
Brand new TDi injector sets:
http://www.vwdiesel.net/forum/index.php?topic=25862.0
Golf Mk2 TDi Van - 250WHP
Reply #1August 29, 2009, 12:54:53 pm
MikkiJayne
  • 235
Hi,
They are totally impossible to get in the UK. I ended up getting mine from Techtonics http://www.techtonicstuning.com/showpart.asp?partnum=104.150
They are the same on all 4 cylinder engines with the intermediate shaft.
Reply #2August 29, 2009, 10:28:03 pm
subsonic
  • 1836
Check out this link.
Looks like they are the same.  Part numbers are listed.
http://www.vwdiesel.net/forum/index.php?topic=1676
Reply #3August 30, 2009, 04:26:59 am
smutts
  • 720
    ClackClackClackClackClack
Bugger! >:(
Reply #4August 30, 2009, 07:07:56 am
ryanp
  • 269
does it sound like mine need replacing? should it have no movement at all?
What about machining it down like on an IDI? my pal has a lathe!
Cheers
Ryan
Reply #5August 30, 2009, 01:32:20 pm
snakemaster
  • 405
the last one i can mind had a small bit off play , i have a spair 1z in my garage that i poped and no belt on her so will have a look tomorrow
Reply #6August 31, 2009, 02:46:22 am
ryanp
  • 269
ta, dont want to go to all this trouble if a little play is not going to cause me any worries!
Reply #7August 31, 2009, 04:38:10 pm
snakemaster
  • 405
on my shaft you can slide it out and in 3.5mm but up and down and side to side .3mm to .5mm
Reply #8September 01, 2009, 10:17:03 am
blackdogvan
  • 574
have you guys read Andrew's thread on this subject? its a good read...
1991 Vanagon 1.9 mTDI
Reply #9September 04, 2009, 11:25:10 am
ryanp
  • 269
do you have a link to the tread, I searched but he has so many posts!!
Thanks
Ryan
Reply #10September 18, 2009, 11:40:44 am
myke_w
  • 1099
Re: Intermediate shaft bearings. Are they the same as IDI and where to get them!
« Reply #10 on: September 18, 2009, 11:40:44 am »
Ryanp I can send you some - you could be the new UK connection :)
I'll likely be in the UK later this year, I'd be interested in meeting up.
Reply #11September 18, 2009, 03:33:44 pm
ryanp
  • 269
« Reply #11 on: September 18, 2009, 03:33:44 pm »
Myke,
I personally dont need them anymore, but i'd be interested in a chat, Drop me a PM!
Ryan
Reply #12November 06, 2009, 06:12:50 am
Reply #13December 04, 2009, 08:33:29 am
scottmandu
  • 20
    • http://www.advancedautomotion.com
Bugger! >:(
According to VW if you need those bearings you have to buy a new block. However there are plenty available to the aftermarket.
Reply #14December 05, 2009, 12:20:08 am
Some brands are ready to go after the install and some must be reamed bigger.
I buggered a set on my first try (the ready to go type), after installing 'em the shaft wouldn't fit. The kind reamed that needs reamed would take care of that. ;)
