Author Topic: MKIII Splined steering Adapter  (Read 2000 times)
August 28, 2009, 06:07:38 am
Torchd
  • 372
« on: August 28, 2009, 06:07:38 am »
Hey guys!!
I need to change the ignition switch so need to remove the splined steering adapter. Is there a way to do it without using a puller, if not can I make a home made puller? I\ll appreciate if someone can send a simple but effective puller design.
Cheers.
Reply #1August 29, 2009, 06:28:24 am
BellCityDubber
  • 251
Re: MKIII Splined steering Adapter
« Reply #1 on: August 29, 2009, 06:28:24 am »
take the column stalks off and use large vicegrip and a hammer....
there should be a small small lip... like 1/16th of an inch, and get the edge of the vice grips right up against that lip and hammer on the vice grips..... that's how I managed to get mine off...
Reply #2August 29, 2009, 02:47:19 pm
macka
  • 957
« Reply #2 on: August 29, 2009, 02:47:19 pm »
take a piece of flatbar about 5 cm longer then the bolt holes in the steering wheel. Drill 3 holes in it, one in the middle, and one over each hole in the steering wheel base. now you need to make the 2 outer holes slightly larger then the bolts that fit in those outer holes. The middle bolt should be at least 1/2 the size of the center bolt holding the steering wheel on. It to has to fit through  the middle hole and be at least 15cm long, or 2cm longer then the outer bolts. You will need to have a nut that fits the center bolt. Now bolt the rig with the 2 outer bolts to the wheel. Insert the center bolt through the hole threading the nut underneath the flat bar to the bolt. Now make sure the center bolt has a solid seat on the center post. Now tighten the nut towards the bolt head, and in about 4 turns the wheel will be off.
Quote from: Vincent Walden
