Author Topic: Help needed  (Read 2078 times)
September 25, 2005, 10:09:38 pm
vixentd
  • 88
Help needed
« on: September 25, 2005, 10:09:38 pm »
1991 vw 1.6 turbo diesel leaking exhaust fumes at the flange that the turbo charger bolts to the exhaust.  I noticed two bolts are missing, or studs?  Anyone tell me if they are bolts or studs. Wonder if they are replace if it will seal or will need a gasket.  Little smelling inside!!
how much work replacing that 4 inch square gasket?
Reply #1September 26, 2005, 12:17:38 am
Maarten
  • 339
Help needed
« Reply #1 on: September 26, 2005, 12:17:38 am »
Normally they are studs, but they can be bolts too.. just what you prefer.
There needs to be a metal gasket.
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #2September 26, 2005, 05:37:45 am
dieselpete
  • 15
Help needed
« Reply #2 on: September 26, 2005, 05:37:45 am »
i had two of the studs snap when i attempted to remove the downpipe. i drilled the old studs, and retapped the with 8mm studs. the corresponding holes in the downpipe also had to be opened up to match, but it wasnt too difficult- just make sure you stuff a rag in the exhaust turbine housing to keep the shavings out
                              cheers
