Author Topic: 1.9TD Coupe Project  (Read 58782 times)
August 23, 2009, 10:13:05 pm
zagarus
  • 619
1.9TD Coupe Project
« on: August 23, 2009, 10:13:05 pm »
Seeing as I haven't posted anything on here about my build I figured I'd give a few teaser pics :P
Fully rebuilt 1.9TD with a T3, custom intake made by a buddy, Giles fuel pump with calibrated injectors.  Gonna get the passenger performance DP ceramic coated this time.   Also going to be running an AWIC, 25psi after break in.  And all stuffed in a 1992 Jetta Coupe, should be fun :D
« Last Edit: May 17, 2010, 06:49:51 pm by zagarus »
Reply #1August 23, 2009, 11:41:10 pm
Syncroincity
  • 727
Re: Few Pictures of the build
« Reply #1 on: August 23, 2009, 11:41:10 pm »
 :o Wow, nice engine! Your friend planning on making any more intakes?
Jetta's gonna scoot! 8)
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #2August 24, 2009, 04:37:01 am
catlin_cava
  • 1954
« Reply #2 on: August 24, 2009, 04:37:01 am »
thats one Sweet looking motor.
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #3August 24, 2009, 05:02:26 am
arb
« Reply #3 on: August 24, 2009, 05:02:26 am »
SWEET !!! I like your turbo pointing up like that :-) Have not seen an oil pressure sending unit that big in many years,,,
Reply #4August 24, 2009, 06:40:51 am
Op-Ivy
  • 513
« Reply #4 on: August 24, 2009, 06:40:51 am »
Lookin good Tom! Can't wait to see the finished product!
Reply #5August 24, 2009, 11:27:21 am
GEE-BEE
  • 1604
« Reply #5 on: August 24, 2009, 11:27:21 am »
I sold the same early production downpipe for 100.00 since it wouldnt fit my K14
Techtonics used it as a mock-up thou...
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #6August 25, 2009, 04:30:15 pm
macka
  • 957
« Reply #6 on: August 25, 2009, 04:30:15 pm »
when I go back to school and I have to have a "projects" I may knock out a few, but that won't be until feb 2010. I really don't like to bring work home.
Quote from: Vincent Walden
Reply #7September 02, 2009, 11:13:51 am
xxkoadyxx
  • 179
« Reply #7 on: September 02, 2009, 11:13:51 am »
wow that engine is clean
93 vw Golf 1.9TD soon to be stage 3 malone TDi (project)
2003 VW 1.8T Passat (daily)
Reply #8September 02, 2009, 11:18:17 am
« Reply #8 on: September 02, 2009, 11:18:17 am »
too bad he didnt actually take the time to make it a dual plenum intake... with the tapered slit in the top plenum, would have been tits.
Reply #9September 02, 2009, 11:50:26 am
motörhead
  • 12
« Reply #9 on: September 02, 2009, 11:50:26 am »
newb question...what is that exhaust manifold off of?  I think that it would be ideal for the Toyota swap I am planning...clearance with the starter and a low-hanging turbo is a problem, and that definitely wouldn't interfere...standard T3 flange I assume?
Thanks
Reply #10September 02, 2009, 02:46:35 pm
53 willys
« Reply #10 on: September 02, 2009, 02:46:35 pm »
Thanks
correct me if i'm wrong here...but IO think thats a regular Turbo diesel VW manifold...with a T3...but it's the VW T3??(non standard?)
Reply #11September 03, 2009, 05:12:22 am
motörhead
  • 12
« Reply #11 on: September 03, 2009, 05:12:22 am »
I'm used to two different types...a "normal" one that has the bolt holes in a rectangle, and the turbo dodge one that has one bolt out a bit further than "normal"...I've seen triangular flanges and trapezoidal ones on this site, although it is likely that the KKK turbos might use those...as for the manifold, the reason I inquire is that if it's a stock one that is simply flipped, then that might make my life easier when I go to put the motor into my Toyota truck, as the starter and the turbo are very cosy with the turbo hanging down.
Thanks
Reply #12September 03, 2009, 10:32:21 am
motörhead
  • 12
« Reply #12 on: September 03, 2009, 10:32:21 am »
Upon looking at the TDI swap threads on tdiclub again, I realize that the IDI mainfolds generally carry the turbo like my 90 caravan and 87 daytona, and the TDI ones seem to hang it...my apologies.
Reply #13January 02, 2010, 10:15:39 pm
zagarus
  • 619
« Reply #13 on: January 02, 2010, 10:15:39 pm »
Holy crap forgot about this thread here. To answer a few of those orientation and parts questions before (im sure they have been answered but what the hey).  Turbo is a stock vw Garrett T3 on a stock exhaust manifold. The flange on the turbo is a trapezoidal shape, not a regular rectangle like most garrett manifolds. As for the intake I would like to get a PD150 intake down the road because those look amazing.
Now for a few more pictures, progress has been slow now because the car is sitting in a tent, and well its winter.
will have it running come spring time :D
Reply #14January 02, 2010, 11:18:25 pm
« Reply #14 on: January 02, 2010, 11:18:25 pm »
Looks good!!
