Author Topic: MKIII Rad fan schematics  (Read 2957 times)
August 18, 2009, 08:12:14 am
Torchd
  • 372
« on: August 18, 2009, 08:12:14 am »
Hey guys...
My cars radiator fan wirinf is all burnt and faulty and I want to re do it. Would any have the wiring schematics for the MKIII radiator fan? My car is a 95 AAZ with air con and big 450W twin radiator fan.
I have looked for it in my Haynes manual, altho it does cover my car but schematics found in there are for the small low 2 speed fan.
Any help is greatly appreciated!
Reply #1August 18, 2009, 10:44:56 am
Zulfiqar
  • 254
Re: MKIII Rad fan schematics
« Reply #1 on: August 18, 2009, 10:44:56 am »
does it have all the switches - it should be pretty much the same as the mk2 with A/C, Its run by 3 relays if Im not mistaken.
Diesel IS the future
Reply #2August 18, 2009, 09:31:48 pm
Torchd
  • 372
« Reply #2 on: August 18, 2009, 09:31:48 pm »
Yes, had all the switches. But its alot different from an MKII. Its quite complex.
Reply #3August 19, 2009, 02:15:54 am
Torchd
  • 372
« Reply #3 on: August 19, 2009, 02:15:54 am »
Hellloooooooo  any one?
Reply #4August 19, 2009, 03:31:12 am
Zulfiqar
  • 254
« Reply #4 on: August 19, 2009, 03:31:12 am »
A better option would be to make your own schematic - if it has the 3 pin rad plug you are golden, or do it like me, I have a 94 degree switch and a 102 degree switch in my radiator wired to two relays with a snubber on each - one relay is low speed (honda mini relay) with a 0.5 ohm 50W resistor in the +ve wire and a bosch 40 amp relay on the fan cowl kicking it to full blast via the secondary fan switch and the HPS in the ac liquid line. Im using a GATE fan whose shroud looked like the golf mk2 shroud, its rated at 350W
The snubbers save the relay contacts from welding and the relays have flyback diodes saving the fan switches from eroding - Another protection would be a 0.47uf cap on the fan leads near the fan to kill off any radio noise or spike interference when the fan windings are de-energized.
when I got my car it didnt even have a rad - or fan or even fan wiring. lol
Reply #5August 19, 2009, 04:03:50 am
Torchd
  • 372
« Reply #5 on: August 19, 2009, 04:03:50 am »
Thanks Zulfiqar... but this all sounds rocket science to me, im pretty poor with wirings!! My mkII has all original 350W fan setup and it has always worked without missing a beat.
My mkIII however has most of the stuff original but its wiring has been played with. It has the 4 pin 450 or 500W twin fan. The secondary fan is drive via a belt from the primary fan. I just installed a brand new primary and seconday fan, new belt, new glow plugs, new fan control unit and many other things. I was trying to fix the wiring and I already burnt my 100% working ignition switch and brand new glow plugs relay which I installed yesterday.
So earlier my car was drivable with fan running directly but now it doesnt even start!! My dad is proper pissed at me! Now i am looking for glow plugs relay, fusebox (cuz I think I managed to fu_k that up too) and an AAZ control unit which controls glow plug timings and EGR.
Reply #6August 19, 2009, 04:26:49 am
Zulfiqar
  • 254
« Reply #6 on: August 19, 2009, 04:26:49 am »
firstly the stupid arrangement of VW GP relay inside the cab doesnt make sense to me, tons of amps inside the cab = fire hazard
Reply #7August 19, 2009, 04:40:31 am
Torchd
  • 372
« Reply #7 on: August 19, 2009, 04:40:31 am »
yeha!!  it is.
BTW, are you coming tomorrow? Let me know if you are cuz i'm in Abbotabad at the moment and I will come to ISB if you come.
Reply #8August 19, 2009, 11:03:55 am
Zulfiqar
  • 254
« Reply #8 on: August 19, 2009, 11:03:55 am »
yep Im comin over tommorow evening - have little business to do on Friday then Im free -
Reply #9August 19, 2009, 11:26:47 pm
Torchd
  • 372
« Reply #9 on: August 19, 2009, 11:26:47 pm »
Okay.. i shud be there by then!
Reply #10August 22, 2009, 11:53:19 pm
Torchd
  • 372
« Reply #10 on: August 22, 2009, 11:53:19 pm »
Anyone with the schematics guys?
Reply #11August 24, 2009, 06:41:28 am
Torchd
  • 372
« Reply #11 on: August 24, 2009, 06:41:28 am »
helloooooooo
