Author Topic: weight of complete 1.6 and 1.9 TD engines  (Read 39935 times)
August 13, 2009, 06:09:53 pm
ilikevwdiesel
  • 1202
« on: August 13, 2009, 06:09:53 pm »
anybody know the weight of a complete MF or AAZ engine, complete meaning engine with pump, turbo, alternator and clutch/flywheel?
thanks in advance
My Bio
Reply #1August 14, 2009, 12:39:26 am
Syncroincity
  • 727
Re: weight of complete 1.6 and 1.9 TD engines
« Reply #1 on: August 14, 2009, 12:39:26 am »
Weight of a complete AAZ is 400 lbs. I shipped one in a wood crate, it was 432 lbs
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #2August 14, 2009, 04:23:06 am
ilikevwdiesel
  • 1202
« Reply #2 on: August 14, 2009, 04:23:06 am »
thanks I appreciate that info.
My Bio
Reply #3August 14, 2009, 05:09:54 am
« Reply #3 on: August 14, 2009, 05:09:54 am »
lifted this from a rebuilder site for the 1.6
Shipping Weights:
1-Block 80 lbs
2-Head 35 lbs
3-Crank 38 lbs
4-Rods 6 lbs
5-Pistons 8 lbs
6-Oil Pump 5 lbs
7-Oil Pan & Valve Cover 8 lbs
8-Gasket Set & Bearings 3 lbs
Total Weight For Kit 183 lbs
Reply #4August 14, 2009, 07:54:18 am
arb
« Reply #4 on: August 14, 2009, 07:54:18 am »
Shipping Weights:
1-Block 80 lbs
2-Head 35 lbs
3-Crank 38 lbs
4-Rods 6 lbs
5-Pistons 8 lbs
6-Oil Pump 5 lbs
That feels about right... my Caravan is really sitting high with such a light engine...
Reply #5August 14, 2009, 08:28:48 am
« Reply #5 on: August 14, 2009, 08:28:48 am »
400 lbs is not light
a small block chevy is 525 or something dressed running.
i can not lift 400 lbs, i dont care what anyone says. and i can pack a whole 1.6 MF.
a 22r weighs 315 lbs fully dressed. i can pack one of those too..
Reply #6August 15, 2009, 06:21:27 pm
Laurentian
« Reply #6 on: August 15, 2009, 06:21:27 pm »
Great post, always wondered about weight for choosing a suspension.
Most coils are available fo 8V, 16V,. or V6 swap for MKII.
Would also like to know weight of :
8V
16V
V6
MF
AAZ
Thanks much if anyone knows ;)
Reply #7August 15, 2009, 07:38:15 pm
Turbinepowered
  • 1206
« Reply #7 on: August 15, 2009, 07:38:15 pm »
Is your rabbit on roids or are you?  ;D
For what it's worth... my personal record is a pair of shortblocks at once. I had chains, and I had my nifty little shackle plates that I made to lift and move shortblocks more easily, secured fore and aft with two 11mm bolts...
I only had to go a short way, but I'd be willing to be those shortblocks (gasser 8v) totaled over three hundred. There doesn't seem to be a hugely noticeable difference between a 1.8 8v gasser shortblock and a nonturbo 1.6 diesel shortblock.
« Last Edit: August 15, 2009, 07:40:02 pm by Turbinepowered »
Reply #8August 15, 2009, 09:19:37 pm
arb
« Reply #8 on: August 15, 2009, 09:19:37 pm »
I'm with you :-) Although I usually agree with Rabbit on Roids, my personal experience is the 1.6L TD is lighter than th Dodge 2.5 NA engine my Caravan had OEM.
Reply #9August 16, 2009, 12:37:04 am
« Reply #9 on: August 16, 2009, 12:37:04 am »
no no no. just because im 6'7" doesnt mean im on roids. those engines are NOT 400 lbs. a 22r is WAY WAY bigger than a MF.
i will take a pic side by side just to prove a point if i have to. these engines are NOT 400 lbs. i dont care what anyone says. no one can tell me that one is 400. the V6 out of my toyota isnt even 400, and it has 2 heads, 2 more pistons, 1 more cam, and a bunch more *** than a 1.6. they weigh like 250 to 300 lbs max. i would bet my left nut on it!
Reply #10August 16, 2009, 08:20:02 am
« Reply #10 on: August 16, 2009, 08:20:02 am »
Maybe that AAZ was shipped with a tranny? I would think that the aaz block couldn't be much more than the 1.6 since they will basically bolt up in the same engine compartment with no problems I would guess that it would be just over 200?
Rabbit on roids:  I am with you on the carrying engine stuff. My best was carrying a Ford 400 Just block crank and pistons 25 to 30 yards to my trailer to haul away. That was 14 years ago when I was a powerlifter and not worried about hurting myself. I could deadlift 700lbs, but never got it clean in competition. I have no idea what that 400 weighed but it was about all I could handle!
Reply #11August 16, 2009, 08:33:15 am
catlin_cava
  • 1954
« Reply #11 on: August 16, 2009, 08:33:15 am »
If me and my old man can pick up an AAZ with little fight they ain't 400lbs lol.
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #12August 16, 2009, 10:50:44 am
« Reply #12 on: August 16, 2009, 10:50:44 am »
FINALLY! last time we went over this, i lost bad, everyone agreed with someone else that these engines are NOT 400 lbs. c'mon guys, a small block chevy V8 is ALL CAST IRON. they have 2 heads! and a huge block! there is no chance a 1.6 or 1.9 with or without trans and accessories weighs within 100 lbs of a small block. they are like 300 max, and thats with a trans and flywheel bolted on still. but yea, i think a safe weight is about 200 lbs. maybe 250 if it has all the accessories still.
Reply #13August 16, 2009, 02:28:24 pm
ilikevwdiesel
  • 1202
« Reply #13 on: August 16, 2009, 02:28:24 pm »
Jack at VWdieselparts.com sez a complete 1.6 TD weighs in at 385 lbs. I have no reason to doubt him he's probably shipped a hundred of em in his day.
My Bio
Reply #14August 16, 2009, 02:59:26 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #14 on: August 16, 2009, 02:59:26 pm »
Just heaving the head with the turbo attached nearly killed me! What is it made of, depleted uranium? :P
