Author Topic: WTB piston rod and Passat oil filter flange  (Read 5721 times)
August 04, 2009, 08:17:13 am
turbosuzi
« on: August 04, 2009, 08:17:13 am »
I need a cast iorn vac pump and a 1.6td std rod bearing cap.
I live inCalifornia and my zip code is 93614.
I forgot, I also am in need of an angled oil filter housing.
« Last Edit: August 06, 2009, 10:20:11 am by turbosuzi »
Reply #1August 04, 2009, 09:19:22 am
Re: WTB Vac pump and 1.6 td bering cap
« Reply #1 on: August 04, 2009, 09:19:22 am »
I have the vac pump you need, and if you need a non turbo oil filter flange then I have one of those as well
Reply #2August 04, 2009, 02:32:19 pm
« Reply #2 on: August 04, 2009, 02:32:19 pm »
i think he means the angled oil filter flange off a van or something.
every other flange ive seen sits at a right angle to the face of the block.
Reply #3August 04, 2009, 03:04:55 pm
« Reply #3 on: August 04, 2009, 03:04:55 pm »
In that case I can`t be of assistance. I do still have the vacuum pump if it`s the same though...
Reply #4August 05, 2009, 07:51:14 am
« Reply #4 on: August 05, 2009, 07:51:14 am »
You really shouldn't replace just the rod cap.  They are matched to the rod.  You should replace the entire rod if the cap is a problem.
Andrew
i always thought they were kinda a matched set too.
by the way, how did you just loose or mess up just the rod cap?
Reply #5August 05, 2009, 02:37:36 pm
turbosuzi
« Reply #5 on: August 05, 2009, 02:37:36 pm »
Oil filter blewout and lost all oil , enging seized crank shaft was toast, allthe rods and caps are reusable but I mangled one cap while removing it.
I already got the vac pump.
Does anyone have an extra rod available?
I do need the oilfilter adapter for a longitudinal motor it is for my brothers samurai.
Thanks guys.
Reply #6August 06, 2009, 08:53:30 am
« Reply #6 on: August 06, 2009, 08:53:30 am »
good luck getting the Audi/quantum filter flange.
Reply #7August 06, 2009, 10:18:55 am
turbosuzi
« Reply #7 on: August 06, 2009, 10:18:55 am »
I got one from a Passat, but cant find another for my brother.
Reply #8August 06, 2009, 07:19:31 pm
dieselherb1
  • 354
Re: WTB piston rod and Passat oil filter flange
« Reply #8 on: August 06, 2009, 07:19:31 pm »
I just happened to have a Quantum (angled) oil filter mount. How much is it worth to you? I know they are hard to come by.
Reply #9August 06, 2009, 10:51:20 pm
turbosuzi
« Reply #9 on: August 06, 2009, 10:51:20 pm »
I believe I paid $15.00 for mine. Is that agreeable to you plus shipping to 93614 Clifornia?
And I am still looking for a good piston rod.
Reply #10August 09, 2009, 09:49:05 pm
turbosuzi
« Reply #10 on: August 09, 2009, 09:49:05 pm »
No extra piston rods lying arround?
Reply #11August 10, 2009, 04:55:40 am
dieselherb1
  • 354
« Reply #11 on: August 10, 2009, 04:55:40 am »
I'll look for a rod
Reply #12August 10, 2009, 05:06:48 pm
turbosuzi
« Reply #12 on: August 10, 2009, 05:06:48 pm »
How does $30.00 plus shipping sound for a rod and the angled flange?
Reply #13August 11, 2009, 04:32:33 pm
turbosuzi
« Reply #13 on: August 11, 2009, 04:32:33 pm »
Bump.
 sorry to be a pain but school starts in a two weeks and I need the connecting rod to put the 1.6 back together for school.
Reply #14August 11, 2009, 05:10:29 pm
dieselherb1
  • 354
« Reply #14 on: August 11, 2009, 05:10:29 pm »
Okay I found them and $30+ sounds good. Send me a PM with your address, I'll check shipping.
Herb
