Power Steering Gone Byebye...
Topic: Power Steering Gone Byebye... (Read 2982 times)
July 30, 2009, 07:56:41 pm
July 30, 2009, 07:56:41 pm »
A month or two ago I was out driving on the freeway for an hour or two. When I came off I noticed my PS was gone - armstrong steering, yay! Pulled in at the next spot and took a look, belt had jumped off or broken and was long gone.
Since the only thing that didn't have a belt over it was the PS pump I drove for a while without power steering. Now I've gone and put a new belt on today only to discover there's STILL no power steering!!
Pump was whining quite a bit today with the new belt on but seems to have quieted down. Any chance I just got a bunch of air in the system somehow or something? Or am I probably looking at a new pump?
July 31, 2009, 05:33:48 am
Re: Power Steering Gone Byebye...
July 31, 2009, 05:33:48 am »
Pump might be seizing. That might be why the belt flew off in the first place.
July 31, 2009, 07:24:44 am
July 31, 2009, 07:24:44 am »
Yeah, I was wondering about that possibility. It spun very freely when I was putting the new belt on though...
July 31, 2009, 07:32:10 am
July 31, 2009, 07:32:10 am »
Two thoughts FWTW:
- under normal circumstances you should see turbulence in the power steering reservoir with the engine running, as the pump moves fluid thru the system and back into the reservoir.
- the procedure to rid the system of any suspected air is to turn the steering wheel from lock to lock 4 or 5 times with the engine running.
July 31, 2009, 08:12:47 am
July 31, 2009, 08:12:47 am »
Thanks Vince, was kind of hoping you'd chime in...
For #1 I did take a look yesterday for exactly that reason. No signs of movement in the reservoir really. I'll look again because I was mainly focusing on the dipstick when I checked.
I'll give #2 a shot too...
July 31, 2009, 10:52:27 am
92EcoDiesel Jetta
July 31, 2009, 10:52:27 am »
My power steering was not working either when I bought the car. fluid was full, belt was tight, pump spun freely w no noise. There was no movement in the reservoir as I recall. I was lucky to find a good used pump for $7, installed it when I did the timing belt and and now have power steering!
July 31, 2009, 01:01:39 pm
July 31, 2009, 01:01:39 pm »
Yeah, that looks like where I'm at now too... Checked today, there is definitely NO movement of fluid in the reservoir whatsoever. New pumps are listed at $150... booo!!
July 31, 2009, 01:19:51 pm
July 31, 2009, 01:19:51 pm »
Urgh... OK, so here's where it gets fun...
My car has an '88 or so motor in a '94 body. I wasn't the one to do the swap... For the MOST part all the '88 accessories and things were left on the motor. The '94 PS pump is listed at about $200 whereas the '88 one is $150, so obviously I'd want to go with the cheaper pump. Looking at the pictures it's difficult to see much of a difference - they seem to have their mounting holes in the same place, etc.
I know I've read before that you can bolt the AAZ brackets to the MF engines and vice versa, what about the pumps themselves?
