Author Topic: aaz conversion question?  (Read 2231 times)
July 27, 2009, 11:42:41 am
allsierra123
« on: July 27, 2009, 11:42:41 am »
I was just recently informed I was playing with disaster, Using the stock aaz exhaust manifold and turbo? in my vanagon at a 50* setup. Anyone have anymore info on this?
Reply #1July 27, 2009, 12:40:55 pm
  • 1739
Re: aaz conversion question?
« Reply #1 on: July 27, 2009, 12:40:55 pm »
It's not a disaster, just a couple of easily overcome hurtles. One thing is where  the exhaust manifold and turbo sit on an AAZ will cause interference with the left side engine support. There are 2 ways around it. Either you or have someone fabricate a new support ,side stepping the AAZ setup, or use an exhaust manifold from a JX engine and the appropriate turbo to match.This would be my preference and i even have one of those manifolds to sell [imagine the coincidence!], as i'm not going to bother turbo changing my Transporter. The other issue is the oil drain for the turbo. There may be a question as to whether the drain that goes into the block is low enough. The better way is to use ,again , a JX oil pan [got one of those also!!!], and have a new drain line found or made up.
Reply #2July 27, 2009, 01:03:10 pm
allsierra123
« Reply #2 on: July 27, 2009, 01:03:10 pm »
Well my engine is already in. I had no interfearance issue with the mounts on it. I got a jx pan with the return bung in it. Which is plugged with a bolt at the moment. Still have the stock drain line hooked up. So I guess all Im wondering is am I damaging my engine at the moment by running it setup this way? If so I need to change the drain line to the bottom?
Reply #3July 27, 2009, 01:05:24 pm
allsierra123
« Reply #3 on: July 27, 2009, 01:05:24 pm »
Im just being extra careful after spending so much money on this conversion.
Reply #4July 27, 2009, 01:28:16 pm
  • 1739
« Reply #4 on: July 27, 2009, 01:28:16 pm »
So i don't understand what the question is then. Are you concerned because the motor is tilted so far down on it's side ? If so, don't sweat it , the factory produced vanagons like that.
