Author Topic: Rough idle  (Read 1984 times)
July 26, 2009, 12:55:39 am
Hiho
  • 77
Rough idle
« on: July 26, 2009, 12:55:39 am »
Hello,
my 1.5d Golf (rabbit to most of you) has a very rough idle. Increasing the revs makes it mostly go away. Its fine while driving. Any ideas on where to look? I have checked the valve clearances and they are all in spec.
Cheers
Matt
1978 1.5 GLD
1978 1.6D soon to be TD
Reply #1July 26, 2009, 01:24:24 am
maxfax
  • 2126
Re: Rough idle
« Reply #1 on: July 26, 2009, 01:24:24 am »
Check your fuel filter, and check for fuel leaks... Check the clear (or if it is like most of them now, the cloudy) inlet tube from the fuel filter to the injection pump for bubbles (sign of it sucking air somewhere.....  Make sure your connections to the pump are tight, and the sealing washers are in tact..
Next on the list would be to check the timing which would require some special tools...  Check out here for a good description of the procedure..
http://vincewaldon.com/index.php?option=com_content&task=blogcategory&id=14&Itemid=28
You got the valve clearance covered, the next would be to have the injectors tested.. This would require removing them and having someone (like a diesel repair shop) pop test them...
While you have the injectors out, if you have access to a compression gauge it couldn;t hurt to give that a check..
Is this something that happened all of a sudden, or has it been gradual??   Any chance of bad fuel? (now sure how your diesel is down under) It coudl also be possible that either your idle is set a bit too low, or you culd have a bad motor mount or two which would make it feel alot rougher...
Good luck!!
Reply #2July 28, 2009, 02:17:57 am
Hiho
  • 77
Re: Rough idle
« Reply #2 on: July 28, 2009, 02:17:57 am »
Thanks for the detailed procedure to solve this problem! I will be replacing the nozzles soon and will check the compression while im at it. The timing is correct. The car has been like this since i purchased it
1978 1.5 GLD
