Author Topic: So im thinkin' of painting...  (Read 7576 times)
July 23, 2009, 09:08:38 pm
« on: July 23, 2009, 09:08:38 pm »
Now I'm going to explain my thought process, and tell me if it sounds solid or not :P
What i will do is roll on a solid base coat of Tremclad, wetsand (??) it with maybe a 400 to get it smooth all over, and then apply the finishing coat of rattle can with a final wetsand of 2000....
Will the last sand ruin the coat of paint? i did a portion today with 1000 grit.. Smoooth as glass! so i figure if i did a light sand with 2000 after my spray coat, it will leave it smooth as a babies bottom, and lookin good.
What do you guys all think? I would attempt to spray the car wit ha gun, but i ain't got no CO2   :(
I think it should come out quite nice. I'm in the process of filling in the body line to make a cleaner, sleeker look. its gonna be nice :)
I've started with the base coat gloss black.. lol shoulda started this thread first.... lmao Tell me what you think, and if i should change some techniques early on or w.e
Criticism is WELCOME! i want to learn how to do this properly :) thanks guys
Reply #1July 23, 2009, 10:05:08 pm
maxfax
  • 2126
Re: So im thinkin' of painting...
« Reply #1 on: July 23, 2009, 10:05:08 pm »
FLAMES!!! You need flames!!!!! ;D
Reply #2July 23, 2009, 10:30:24 pm
drrtybyl
  • 146
« Reply #2 on: July 23, 2009, 10:30:24 pm »
It all depends on what you're looking for.  If you want "professional" results, lots of practice with a gun and compressor using cheap paint is a good idea... Then the process becomes lots of layers with clearcoat, wetsanding, polishing, clearcoating, ad infinitum...
I think the tasteful roadwarrior/hood look is a refreshing alternative to the sea of robotically finished factory boxes being driven around...  Have you considered welding large spikes or horns to the bumper supports?
'79 Rabbit Diesel L
'94 Chevy 2500 6.5TD
'96 BMW 318ti
Reply #3July 24, 2009, 05:38:09 am
« Reply #3 on: July 24, 2009, 05:38:09 am »
Why is it BLACK? Where is the army green...I am dissappointed, unles this is just practice.
I was going send you a roll of 3M masking tape for free when you put the star on the hood.
« Last Edit: July 24, 2009, 05:39:42 am by theman53 »
Reply #4July 24, 2009, 07:27:26 am
« Reply #4 on: July 24, 2009, 07:27:26 am »
Lucas, I understand your disappointment.. I was thinking to myself "What will this car look like with a baby blue interior and army green paint!?" So I decided to stay with a trusty black. However moving from semi-gloss in to the Gloss region  ;)
HAHA FLAMES!! I don't think i could pull off Flames. lol
Well what i am looking for is a NICE paint job for cheap, and easy work. lol That's why i figured a nice thick coat of roller, sand it down, rattle can it on there lightly, and for the finishing touch 2000 Grit.
Will using the 2000 grit after i lay down the Spray paint wreck the paints finish, or will it sort of buff it and make it smooth?
My last attempt at painting was JUST semi-gloss rattle cans.. nothing else.. lol I want this one to look better. I also want my car to stop being embarrassing :( lol
Reply #5July 24, 2009, 07:43:02 am
« Reply #5 on: July 24, 2009, 07:43:02 am »
definitely use 2000 grit when using black.  any sort of imperfection will show up on a black paint job...  i can see the ripples from the sample paint job you have.  sanding that down with 2000 grit should make it silky smooth and then the final paint job should look beautiful.  you might even want to try 1500 grit then 2000 grit, as 2000 grit might take a while to scuff the shine.  i can't remember how long you have to wait to wax it, but i think its a month or two.
did you prime it?  i highly recommend using tremclad primer.  it goes on orange.  i had a paint job that lasted 3 years without peeling with that stuff  ;) what are you using to paint it?  spray can?  i used one of those cheapie spray kits from princess auto (you need a good compressor) and i didn't bother putting a water/oil separator inline, though you should if you want excellent results, and they sell for relatively cheap anyways.  tremclad by the can is much cheaper  ;)
Reply #6July 24, 2009, 08:09:26 am
drrtybyl
  • 146
« Reply #6 on: July 24, 2009, 08:09:26 am »
Ya, two layers of paper is a good idea if you want the surface to be really even.  If it's not as shiny as you'd like after wetsanding, you should be able to find a drill buffing attachment at an auto parts store for cheap -- use that with some polish on the whole car.
Auto paint is really expensive stuff.. Budget line surface primer/sealer/base/clear for a small/medium size car runs $150-200... Fancy brands like PPG are wayy more  :-X  The labor and materials involved make nice paint jobs seem a lot more reasonably priced.
'79 Rabbit Diesel L
'96 BMW 318ti
Reply #7July 24, 2009, 09:36:38 am
aidan
« Reply #7 on: July 24, 2009, 09:36:38 am »
My golf is nato green, done with a roller. Only did half the masking too as it got boring. Looks fine in rain or from far away. want a photo?
Reply #8July 24, 2009, 02:04:35 pm
« Reply #8 on: July 24, 2009, 02:04:35 pm »
I have painted a couple cars/parts. The one thing I know is make sure the metal and any bondo looks good before you even start painting. If you have a good surface to start with the rest is usually easy. I bought all my stuff in one shot and with the paint guns, compressor, fittings, seporators, air lines and everything else I had about 750.-- in it. But I bought 3 paint guns when now I realize I could have done with 2 or maybe even the one. I figure every job I do now is just time and paint cost, it was well worth my investment I feel. I also think that the better the paint the easier it is to get a good finish, but maybe that is because I am still a beginner.
Reply #9July 24, 2009, 07:40:59 pm
« Reply #9 on: July 24, 2009, 07:40:59 pm »
Well for some reason when i did the roof the little fibers from the roller came out in it :( but when i did the back it came out like a frigging mirror almost. i mean a small amount of texture to it. but i am fine with that :) I think if i just make sure i have enough paint on my roller the bristles will not come out in the paint.. Its just when the brush gets too dry and the paint so tacky that it pulls them off eh? The back portion i did it with a well covered roller and it came out with a perfect finish... Maybe that's all i have to do, is that eh?
Reply #10July 24, 2009, 08:35:06 pm
bvolks73
  • 183
« Reply #10 on: July 24, 2009, 08:35:06 pm »
Here's my brother's 90 TD we sprayed with Tremclad last winter. It still looks good. Here we are spraying it.
 http://www.youtube.com/watch?v=ORV32EdFhKI
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
Reply #11July 25, 2009, 11:08:32 am
« Reply #11 on: July 25, 2009, 11:08:32 am »
your just using the wrong type of roller then.  you'll need to get a high quality foam one.
Reply #12July 25, 2009, 01:48:33 pm
catlin_cava
  • 1954
« Reply #12 on: July 25, 2009, 01:48:33 pm »
2 words: hot pink ;)
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #13July 25, 2009, 06:55:31 pm
jasonsansfleece
  • 162
« Reply #13 on: July 25, 2009, 06:55:31 pm »
Take a piece of duct or packing tape, two-three feet long. Roll the paint roller up and down the tape and all the hairs that might end up in your paint job are stuck to the tape.
Buy the most expensive short nap roller you can find. Its only a couple of extra bucks. Cheap considering the better finish.
Guy
Reply #14July 27, 2009, 06:50:42 am
« Reply #14 on: July 27, 2009, 06:50:42 am »
Well actually, what i found works from Wally-World is a foam roller for acoustic plaster sprayed ceilings  ;D
I never thought a gloss finish would look good, but it does :) lol
