Author Topic: bleed valve on a kkk?  (Read 2361 times)
July 22, 2009, 01:37:36 pm
Benjamin
  • 485
« on: July 22, 2009, 01:37:36 pm »
Guys,
i always had the chance to have garrett.
now i got this KKK turbo, and i wanna put a bleed valve on it for a little bit more boost ;D but how?
with garrett turbo's its so easy, you just put a T between the line from the turbo and the actuator, but with this kkk the hose is metal.
I know you can control the pressure at the actuator itself with kkk turbo's.
My experience is when you use a bleed valve with the pressure a little bit higher than stock the turbo spools quicker, its becouse the bleed valve makes the wastegate start opening much later. And for that, the turbo spools quicker.
I hope you understand what i try to say.
Anyone got a picture from how you got the bleed valve on the kkk turbo?
Greetz, Benjamin
Must make +250hp
Reply #1July 23, 2009, 04:41:08 pm
4wheeler
Re: bleed valve on a kkk?
« Reply #1 on: July 23, 2009, 04:41:08 pm »
I wanna know how to build my own boost control operated from the passenger compartment.
Anyone know a good way how to without any whistle or noise?
Reply #2July 24, 2009, 05:12:02 am
anto
« Reply #2 on: July 24, 2009, 05:12:02 am »
Cut a bit out of the metal pipe and insert a t piece there with the use of some rubber hose and clamp to the original metal left after cutting.
Do you follow me?
Reply #3July 24, 2009, 05:50:12 am
4wheeler
« Reply #3 on: July 24, 2009, 05:50:12 am »
well the only metal pipe on my turbo is the oil feed.  The wastegate to turbo and the intake manifold to LDA are both rubber hose.
I `d like to run it inside the passenger compartment.
Be nice to know how to build a boost controler
Reply #4July 24, 2009, 12:00:21 pm
« Reply #4 on: July 24, 2009, 12:00:21 pm »
get online and search on google.
you take a valve, and drill a special sized hole.
the volvo forums have a pretty good outline.
thats how i learned how to make them.
stupid simple tho. needle valve with a hole in it.
