Author Topic: governor mod issues....  (Read 6685 times)
July 21, 2009, 05:51:49 am
bobmaf
  • 65
« on: July 21, 2009, 05:51:49 am »
hi there i started with the governor mod and finished it i changed the main/long spring with a piece of tube which worked wonders lots of power all thru the range
BUT...
it was kicking out too much black smoke so i didnt have enough time to sort it so a mate said he would do it while i was out
but he messed up and the throttle is now very strange its not got an easy set off throttle like its on or off  full or no throttle if u understand what i mean.....
anyone got any ideas whats happened ????
or can anyone tell me how to put all my setting ie. fuel screw, torx screw, star wheel to standard manufac setting as all my marks have rubbed off
cheers rob
1991 mk2 1.6GTD tuned
1995 mk3 1.9TD Part Tuned(aaz)
Reply #1July 21, 2009, 06:20:54 pm
burnt_servo
  • 278
Re: governor mod issues....
« Reply #1 on: July 21, 2009, 06:20:54 pm »
if you have modified the govenor incorrectly the engine will " hang " ......  meaning when you let off the  throtle the engine rpm doesn't drop down right away  and the engine seems to stay or " hang " at the same rpm that you let the throtle off at for a bit ,  before finally dropping back down to idle .
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
Reply #2July 23, 2009, 05:40:16 am
bobmaf
  • 65
« Reply #2 on: July 23, 2009, 05:40:16 am »
yes it was doing that and i have managed to sort that out by adjusting the position of the throttle arm on the splines at the bottom of the shaft
my main concern now is that when i want to set off slowly from a standing still its got instant power and no gentle throttle (like) i wouldnt be able to tootal along at 10mph in 1st gear ??
also i`m not sure i mentioned it but i only made the main long spring solid and left the intermediate as it was ...
but yes if i can get these little problems sorted i will be very happy as the power is amazing for a 1.6 diesel engine
i hit 120mph at 5,500rpm last night which is an amazing increase in power compared to b4..
Reply #3July 23, 2009, 07:52:55 pm
burnt_servo
  • 278
« Reply #3 on: July 23, 2009, 07:52:55 pm »
what you need to do , is make sure all the springs are left on the governor shaft ( in other words don't remove any of the springs and put something solid in their place , the springs need to be there )  .
then shim just the springs that are side by side roughly 1/8 of a inch to start . you can add more shims / washers later if you need the engine to rev higher .
i used machine screw washers  , i believe i have the larger of the 2 springs shimmed at 1/4 inch and the other at 1/8 of a inch .
also on the top of the pump there are 2 long screws controlling the range of motion of the throtel lever ( ie one can control idle speed and the other controls max rpm )
take the one screw that controls your max rpms and back it out all the way till the throtle lever  no longer contacts the arm when the gas peddle is floored .
Reply #4July 25, 2009, 03:30:47 am
bobmaf
  • 65
« Reply #4 on: July 25, 2009, 03:30:47 am »
:) the only thing that annoys me now is that the throttle is so instant i think ive sorted everything else out with tinkering lol
Reply #5July 25, 2009, 04:29:50 pm
« Reply #5 on: July 25, 2009, 04:29:50 pm »
Take out some of the solid in the main spring until it drives correctly...don't mess with the other springs they will have more drivability issues like you are experiencing.
Reply #6August 10, 2009, 05:20:14 am
bobmaf
  • 65
« Reply #6 on: August 10, 2009, 05:20:14 am »
i am going to strip my pump down today and shim the spring like you said cos its really getting on my nerves now..
has anyone got any idea of the origanal position of the main throttle arm/lever as i didnt mark it when i first stripped it down ??
thanks
Reply #7August 10, 2009, 07:52:36 pm
« Reply #7 on: August 10, 2009, 07:52:36 pm »
No as I think every pump could be different as where they are. Usually it is in the middle somewhere. If you are wrong it is easy to change. Mine was about 5 degrees past the middle lines. See if there was any dirt left behind to help you get close.
Reply #8August 22, 2009, 08:54:38 am
bobmaf
  • 65
« Reply #8 on: August 22, 2009, 08:54:38 am »
its ok not too fussed about it now as i`m tuning an aaz which i`m going to install into my mk2
just one problem the rear engine mount on the AAZ has a different bracket on the engine compared to the gtd i hope the interchangeable as the one on the AAZ is knackerd and the one on the gtd is brand new
Reply #9August 26, 2009, 05:27:12 am
carrizog60
  • 978
« Reply #9 on: August 26, 2009, 05:27:12 am »
any news?
Portugal
Reply #10August 27, 2009, 10:14:22 am
bobmaf
  • 65
« Reply #10 on: August 27, 2009, 10:14:22 am »
yeh spoken to a certain person and the mount bracket on my GTD will fit str8 onto the AAZ so thats a bonus
Reply #11August 27, 2009, 10:25:06 am
snakemaster
  • 405
« Reply #11 on: August 27, 2009, 10:25:06 am »
get rid off the small spring and put a 2mm washer behind the big spring , this is nice to drive , and works well
Reply #12August 28, 2009, 07:01:38 am
bobmaf
  • 65
« Reply #12 on: August 28, 2009, 07:01:38 am »
i`m going to do the gov mod when ive put the engine into my mk2
Reply #13August 29, 2009, 01:22:33 am
« Reply #13 on: August 29, 2009, 01:22:33 am »
thanks
Both of my pumps have factory marks on the shaft and lever, it was easy then.
Reply #14August 29, 2009, 06:56:31 am
bobmaf
  • 65
« Reply #14 on: August 29, 2009, 06:56:31 am »
cheers for that but i aint using the mk2 gtd engine anymore that had that problem
cheers anyway
