Author Topic: Doesn't the ring marked "top" go in the top groov  (Read 4748 times)
June 19, 2004, 03:06:53 pm
DieselsRcool
  • 152
« on: June 19, 2004, 03:06:53 pm »
I just opened a new sealed box of Kolbenshmidt TD pistons with the rings already installed. No ring installation instructions included. They all have the ring marked "TOP" in the second groove.  :?:  The bently says the top ring in TDs are a special alloy and the second ring has a special cut. I have always thought the ring marked "TOP" goes in the top grove.
 Now, do I accept the rings as they are, assuming the factory knows what they are doing or do I assume the factory screwed up and swap them so the top ring goes on top? Crap I hate problems like this.
Any help here guys?  Anyone have a new set of Kolbenshmidt TD rings with instructions that they can check for me?
Between a rock and a hard place.
Reply #1June 19, 2004, 07:15:45 pm
DieselsRcool
  • 152
« Reply #1 on: June 19, 2004, 07:15:45 pm »
I could swear the last set of Kolbenshmidt TD rings I installed were marked "top" on the top ring. On the other hand it seems a stretch to think the factory would install them improperly.
I think I'll install them as is.
Thanks!
Reply #2June 19, 2004, 07:51:22 pm
type53b_gtd
  • 118
    • http://scirocco.cs.uoguelph.ca/gtd/
« Reply #2 on: June 19, 2004, 07:51:22 pm »
Quote from: "DieselsRcool"
Thanks!
A wise move... :)  Rings may be marked either "TOP" or "C" on the top side.
Drew
