Author Topic: Install input shaft seal dry or wet?  (Read 2584 times)
July 10, 2009, 09:36:10 pm
kibs45
  • 46
« on: July 10, 2009, 09:36:10 pm »
Bosch VE.  I can't remember if the seal is installed wet or dry...grrrrr.  Thanks in advance!
Reply #1July 11, 2009, 05:42:18 am
92EcoDiesel Jetta
Re: Install input shaft seal dry or wet?
« Reply #1 on: July 11, 2009, 05:42:18 am »
I recall reading somewhere that you want to lubricate the seal with a bit of vaseline to make the seal go in easier.
Reply #2July 11, 2009, 10:29:47 am
rabbitman
  • 2788
« Reply #2 on: July 11, 2009, 10:29:47 am »
Are you talking about the OD or ID? For the ID I would use oil, diesel, ATF or whatever.
It might be good to use permatex on the OD.
Reply #3July 11, 2009, 05:58:17 pm
Rabbit TD
  • 840
« Reply #3 on: July 11, 2009, 05:58:17 pm »
Any seal should have the correspoding shaft or whatever part that is being sealed lubricated first and I like to take some fine sandpaper and polish the area the seal rides on also if possible.
Reply #4July 12, 2009, 11:59:01 am
« Reply #4 on: July 12, 2009, 11:59:01 am »
i always lubricate a seal before i install it. kinda seems like the lube glues the seal in after the rubber absorbs the lubricant.
