Author Topic: 1.5 head stud kit  (Read 6148 times)
July 04, 2009, 10:57:29 am
tSoG-84bit
  • 188
1.5 head stud kit
« on: July 04, 2009, 10:57:29 am »
Gotta replace the head gasket on my 1.5 diesel, but I can't seem to find any local stores that carry headbolts, let alone head studs. I looked on ARPs catalog, but didn't see anything for 1.5s. Does anyone know where I can order a set? Much appreciated.
84bit 1.6na
Engine died, pulling it apart, putting something new in it's place.
Reply #1July 04, 2009, 11:16:59 am
ilikevwdiesel
  • 1202
Re: 1.5 head stud kit
« Reply #1 on: July 04, 2009, 11:16:59 am »
Don't 1.5 engines use the same stud kit as the 8v gassers? I'm pretty sure the 11mm bolts are all the same. Anyone?
My Bio
Reply #2July 04, 2009, 12:47:10 pm
Turbinepowered
  • 1206
« Reply #2 on: July 04, 2009, 12:47:10 pm »
ARP # 204-4701, VW Golf/Jetta 1.8L & 2.0L 8v  kit
1.5s use 11mm headbolts like the 8v gas engines do.
Reply #3July 05, 2009, 01:18:43 am
tSoG-84bit
  • 188
« Reply #3 on: July 05, 2009, 01:18:43 am »
thanks folks, Just ordered a set, hopefully have this bad boy runnin again before next weekend.
84bit 1.6na
Reply #4July 05, 2009, 11:16:55 am
Rabbit TD
  • 840
« Reply #4 on: July 05, 2009, 11:16:55 am »
Yes get the studs especialy on the 1.5's as they have a problem cracking the block from the bolts not going in far enough.  After you get them you will be glad you did even at the price they are it's probably the best thing you can do to these engines to help it last or from ruining it during assembly.  Guys show pictures here all the time of cracked blocks with 11 m/m bolts that don't go in deep enough, that's the big reason VW went to the 12 m/m bolts but they are stretch type and have their own set of problems though.  I like studs and I'm glad I have them in this engine.
Reply #5July 05, 2009, 12:56:08 pm
maxfax
  • 2126
« Reply #5 on: July 05, 2009, 12:56:08 pm »
X6,000,000
Reply #6July 08, 2009, 12:11:12 pm
camboscams
  • 324
« Reply #6 on: July 08, 2009, 12:11:12 pm »
http://headbolts.com/Volkswagon-Audi-diesel-fasteners.html
Heres where i got mine and i cant complain.
81' White 1.6l Rabbit 4dr Holseted
72' Ford F-250 390cid
2014 JSW 2.0L TDI Stg 2, CP3 HPFP
Reply #7July 08, 2009, 12:17:37 pm
« Reply #7 on: July 08, 2009, 12:17:37 pm »
now your engine should be good to 30+ psi. thats what i was runnin in mine with a stock fiber gasket.
Reply #8July 08, 2009, 12:53:27 pm
« Reply #8 on: July 08, 2009, 12:53:27 pm »
I happened to look in the 77-84 gasser bentley yesterday and it says for 11mm headbolts torque to whatever then crank it a half a turn, for diesels with 11mm bolts there's no extra half turn, just the torque.
Just thought I'd throw that out there :).
Reply #9July 08, 2009, 06:28:22 pm
Rabbit TD
  • 840
« Reply #9 on: July 08, 2009, 06:28:22 pm »
But the problem is that no matter what the torque process used for the diesel they are just too damn short to begin with and a stretch bolt is just a bigg pain in the ass ;)
Reply #10July 09, 2009, 02:13:56 pm
« Reply #10 on: July 09, 2009, 02:13:56 pm »
yup
