what is this sender?
Topic: what is this sender? (Read 2670 times)
July 01, 2009, 09:58:41 am
92EcoDiesel Jetta
July 01, 2009, 09:58:41 am »
What is the one circled in blue? It's on the coolant flange on the end of the head with 4 wires. I looked in the Bently electrical section and could not find it.
July 01, 2009, 12:38:34 pm
ilikevwdiesel
Re: what is this sender?
July 01, 2009, 12:38:34 pm »
it's the glow plug temp sensor. to be sure that's what it is warm up the engine, shut it off, then disconnect that sensor. turn on the ignition but don't start it. If the glow plug lite comes on for around 30 seconds then you can be certain that's what it is.
Look, if corn and kudzu fall in love and have a baby in a lab under the supervision of scientists working in my employ, WHO AM I TO STOP THAT other than the CEO responsible for stopping it???
My Bio
July 01, 2009, 07:59:12 pm
flapjack
July 01, 2009, 07:59:12 pm »
Isn't that what the temp gauge works from as well?
signature
July 01, 2009, 08:40:00 pm
rallydiesel
July 01, 2009, 08:40:00 pm »
On mine that sender was used for the a/c thermostat. Follow the wires. If they connect anywhere into the rad fan/thermoswitch/a/c relay mess it's the a/c thermostat. If not, it's either the glowplug duration switch or the coolant temp sensor (interchangable, I tried it last week).
1991 Jetta TD - sold
2001 Golf TDI - Son's
July 02, 2009, 04:42:51 am
Zulfiqar
July 02, 2009, 04:42:51 am »
by the looks it has 2 separate circuits on earthed and one live - the live one maybe the A/C kill and the second one looks like a sensor for the temp needle.. - what is written on the sensor 120 or 119 degrees?? = the 120 would be a temp gauge switch the 119 is a A/C compressor cutoff - I also have that in my NA
my wiring diagram shows a relay in the fusepanel connected to it, but my car didnt have any sort of wiring to connect it, I just made it work off negative to trip the A/C compressor relay I put in the engine room
Diesel IS the future
July 02, 2009, 04:50:46 am
regcheeseman
July 02, 2009, 04:50:46 am »
It's two temp senders in one body one for guage, one for glow circuit - which is maybe why it's not shown in the bently.
That said - the wire colours are all wrong but that probably a UK/US issue.
We don't get A/C so I could be wrong on that score too.
July 02, 2009, 01:02:29 pm
92EcoDiesel Jetta
July 02, 2009, 01:02:29 pm »
Thanks for the replies! I was able to follow one of the 4 wires from that sender to the AC compressor clutch, which then goes to what looks like a pressure switch (circled in pic), which then goes to the sender on the bottom of the radiator. Looks like the compressor clutch is in series with 2 temp sensors and one pressure switch to cut out the AC. The wiring diagram in the Bently for the 92 Ecodiesel unfortunately does not show any AC components. I still need to figure out what the other 2 wires in the sender is for. I know it's not for the glow plug or coolant temp gauge since those are on the coolant flange on the face of the head (bet #3 glow plugs).
