Author Topic: diff accessory bracket from mk1-mk2?  (Read 2048 times)
June 26, 2009, 06:37:51 pm
jwspin
  • 138
« on: June 26, 2009, 06:37:51 pm »
so im piecing my car together from random parts i have kicking around. the motor is going into a rabbit and when i tried to put the water pump and the accessory bracket that goes on over the water pump it seems like it is interfering with the injection pump/motor mount. do the mk1s have different accessory brackets or am i missing some sort of spacer?
and are there any tricks to bolting it up without taking off the fuel pump, i kinda forgot about those two up water pump bolts when i installed the pump and belts and the motor is all timed up....
-jared
« Last Edit: June 26, 2009, 06:43:11 pm by jwspin »
Reply #1June 27, 2009, 05:48:19 am
allsierra123
Re: diff accessory bracket from mk1-mk2?
« Reply #1 on: June 27, 2009, 05:48:19 am »
I modified my bracket with a drill bit. I can remove it now with ease.
Reply #2June 27, 2009, 06:47:33 am
« Reply #2 on: June 27, 2009, 06:47:33 am »
Yes they are different but they are compatible. There are a few different versions for both the mk1 and the mk2 as well
Reply #3June 27, 2009, 07:22:48 am
jwspin
  • 138
« Reply #3 on: June 27, 2009, 07:22:48 am »
thats what i thought, ill play around with it tonight, good idea with the drill im def gonna do that ive always hated those stupid brackets....
-jared
Reply #4June 29, 2009, 07:44:04 am
jwspin
  • 138
« Reply #4 on: June 29, 2009, 07:44:04 am »
ok now i figured it out. the motor mount that i had was only compatible with the alternator bracket that bolts to the bottom too water pump bolts, i looked under the hood of a new customers rabbit pickup and they had the setup i was looking for. this is cool because it is a simple setup but not cool cause i cant find the bracket....
-jared
