Bently Errata
Topic: Bently Errata (Read 2194 times)
June 24, 2009, 07:48:58 am
92EcoDiesel Jetta
Bently Errata
June 24, 2009, 07:48:58 am »
When I did the timing belt, I found an error in my Bently under: Fuel system-Diesel, 5.4 Camshaft/Injection pump drive belt, step 7. Remove the 2 bolts and one nut holding the lower drive belt cover, then remove the cover.
Problem is it left out the crucial step of: remove the 4 Allen head bolts on the vibration damper and remove the vibration damper, before the cover can be removed.
I called Bently in Cambridge MA and asked if there are other errors and was led to this link of 3 reported errors:
http://www.bentleypublishers.com/vw/jetta/1985-1992/VW-Jetta-Golf-1985-1992-Repair-Manual/gallery-437-3.html
If you know of anymore , please report it here.
June 25, 2009, 12:24:10 am
Natedogg
User+
Re: Bently Errata
June 25, 2009, 12:24:10 am »
hello - didn't know there was a book that covered the Turbo Diesel?
we have haynes manuals over here but only for the petrol!
Would this cover a UK spec GTD (SB code engine) does anyone know?
MK2 Golf GTD 'More Door' in Pasadena Blue
-75mm FK Coilovers
16" Porsche 928 Winter Wheels
223000 miles
June 25, 2009, 02:39:57 pm
smutts
ClackClackClackClackClack
Re: Bently Errata
June 25, 2009, 02:39:57 pm »
Yes it does, but you will still need to keep an eye on this forum for the information that VW doesn't want to share to the European customers.
The SB is a Bloody good engine if you get a good one. But won't suffer fools if you don't get the timing belt right.
June 26, 2009, 12:12:27 am
Natedogg
User+
Re: Bently Errata
June 26, 2009, 12:12:27 am »
no idea - bought it with 230000 miles - belt was done at 190000 so due soon. hoping to time it in with advanced timing - 0.95 to 1.05 i think as per guides on this site and the governor mod etc but need to find someone who i can trust to do this.
off to ebay now to find that book!
-75mm FK Coilovers
223000 miles
June 29, 2009, 01:00:08 pm
Jay
Derv power !
Re: Bently Errata
June 29, 2009, 01:00:08 pm »
Nate, if you find someone selling them in the UK let me know
I've got the normal one too and doesn't help now I've got a GTD
Mind you I got most of my info from the guys @ the GGTI forum
Good bunch of people.
Bently Errata
