Author Topic: Increasing boost pressure  (Read 3243 times)
June 21, 2009, 03:10:54 am
airhead
« on: June 21, 2009, 03:10:54 am »
Ive seen plenty of articles on this site referring to increasing your turbo boost pressure in order to get better performance. The bit I dont get though is, how is this done? Im a novice to this but have a mechanical enough mind to be able to grasp the principal. Ive looked in the FAQs already and didnt find an answer. So lets say for arguments sake Im talking about a Golf Mk2 GTD. What do I do to increase the turbo boost?
Reply #1June 23, 2009, 03:25:18 am
airhead
Re: Increasing boost pressure
« Reply #1 on: June 23, 2009, 03:25:18 am »
Don't all jump in together there, guys!
Reply #2June 23, 2009, 04:18:28 am
MJF
  • 581
« Reply #2 on: June 23, 2009, 04:18:28 am »
What turbo do you have? Does it smoke at full boost? If it doesn't, you have to add fuel first. Dont block wastegate...
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #3June 23, 2009, 04:35:46 am
airhead
« Reply #3 on: June 23, 2009, 04:35:46 am »
Well I'll be getting a Golf 2 GTD, so whatever turbo that has is what I will have. Im really just doing some research at the moment. I did have a GTD for a month but I had to get a refund for it. It did smoke at full boost. I've never altered the boost pressure on a turbo before and I just want to know how its done really.
Reply #4June 23, 2009, 12:33:24 pm
Jay
  • 157
    Derv power !
    • TONA Valet & Detailing
« Reply #4 on: June 23, 2009, 12:33:24 pm »
By turning up the fuelling you also increase the boost and more boost = more fuel until it just becomes a smog storm behind you  ;D  obviously there are also more elaborate ways like bigger turbo and pre-spooling the turbo. Keeping the wastegate shut also increases boost, but can blow up your engine if you've not rebuilt it to withstand the extra boost, is this where you install the MBC (to control the amount of escaped boost and increase/decrease the boost to the engine)?
I understand you'll need to get a 1.9 metal head gasket (1.9 AAZ head too?) in there along with upgraded head bolts/studs.
Mine is not going to be modified until I can give it a good service and find someone to help me out and whose done this before (I'm more IT technical than mechanically technical and only recently got into modifying cars)
Reply #5June 23, 2009, 03:26:55 pm
LoneWolf
« Reply #5 on: June 23, 2009, 03:26:55 pm »
open the top of the pump via the 4 bolts/ screws, rotate the diaphram 180 degrees, seal it up again,
 on the side of the pump near the solid fuel lines is a large screw, prise off any retaining clip/ band and wind it in a tad till you hear a change in revs, compensate for that change usung the 2 screws on the back of the pump near no1 glowplug
 thats the basics for more fuel, but make notes of any adjustments so you can always re-set everything incase you change your mind
 Matt
Reply #6June 23, 2009, 06:40:29 pm
« Reply #6 on: June 23, 2009, 06:40:29 pm »
you should block the wastegate's air supply (cut the boost line to wastegate and put a valve there or just plug it up with something) and then increase the fueling with small increments until you get a slight haze, and then BAM you're done :)  be forewarned that you could damage your engine by doing this.
Reply #7June 23, 2009, 07:16:58 pm
Rabbit TD
  • 840
« Reply #7 on: June 23, 2009, 07:16:58 pm »
Most important thing of all is before you even think about turning screws is to get the EGT and boost gauges first.
