Author Topic: Positrac/Limited slip?  (Read 6256 times)
June 13, 2009, 11:40:18 am
turborabbit
  • 41
« on: June 13, 2009, 11:40:18 am »
Hey, VW gurus, you know who you are, I'm tired of smoking one tire in my '81 caddy/turbocharged '86 Jetta drivetrain. Is there a transaxle I could look for that would get smoke from both tires?? Thanx-warren :-\
If "the more you know, then the more you know, you don't know, then I've got a lot to learn, since I'm forgetting what I thought I knew!!
01Dodge TD
81 Caddy TD
84 Winnebago/Renault TD
86Jetta84GolfCaddyCaddyCaddyCaddy
Reply #1June 13, 2009, 01:31:39 pm
mystery3
  • 774
Re: Positrac/Limited slip?
« Reply #1 on: June 13, 2009, 01:31:39 pm »
Here's one place and I know there are others.
http://www.quaifelsd.com/applications.aspx
Reply #2June 13, 2009, 02:35:12 pm
catlin_cava
  • 1954
« Reply #2 on: June 13, 2009, 02:35:12 pm »
Thats odd, when i would spin my 96 and 97 MK3s, Both Sides would always spin ;D see the video
http://www.youtube.com/watch?v=GZf9v_ti-CA
There is a bit of language in the video.
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #3June 13, 2009, 08:09:47 pm
rallydiesel
  • 1880
« Reply #3 on: June 13, 2009, 08:09:47 pm »
Get the 80% shim kit from Peloquin. Cheap way to get a not-quite limited slip.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #4June 14, 2009, 11:19:32 am
ezekiel
  • 147
« Reply #4 on: June 14, 2009, 11:19:32 am »
Just to be clear, this only works on mk2 (1984 and up) transmissions, since as that is when VW added the "anti-torque steer" 20% LSD.  Shim kits are not available for mk1 transmissions, which don't have the 20% LSD.
Just in case someone with a Rabbit was wondering about the shim kits :)
Sucks for me, I have the nice .75 econ 5th gear, but it's an '82 transmission.
Reply #5June 14, 2009, 01:54:16 pm
rallydiesel
  • 1880
« Reply #5 on: June 14, 2009, 01:54:16 pm »
Good tip. I think the OP has a mkII tranny but it's not really clear.
Reply #6June 15, 2009, 08:20:46 am
« Reply #6 on: June 15, 2009, 08:20:46 am »
Wrong.  I had that same kit in my 4k tranny in my Scirocco.  The "anti-torque steer" was actually just the brass rings that took the slack out of the differential carrier bearings to reduce rattle.  It had nothing to do with a limited-slip system.  VW started using those in all 5-speed transmissions, the 4-speeds did not have them.  Some very very early 5-speeds have been reported to not have them as well.
When you buy the kit, it supplies you with replacement brass rings to install, so you could even install this kit in a 4-speed transmission if so desired.  The Peloquin mini-kit works on all 020 transmissions up to the MK3 cars.
A little bit of real-world testing on this, it only increases the amount of torque between the wheels about 20-30 ft-lbs, so it's not much use on dry pavement.  My Scirocco had a hot 2.0 gasser engine and on dry pavement around turns, the inside wheel would still spin under heavy throttle.  The only time it was really useful was on loose/slippery roads.  Unfortunately there is no cheap easy replacement for a true limited slip differential.
Reply #7June 15, 2009, 10:47:26 am
ezekiel
  • 147
« Reply #7 on: June 15, 2009, 10:47:26 am »
I was always under the impression that it had to have had the shims to begin with, that's good to know that any 020 can use the kit.
could have been a bit less blunt, "that information is incorrect" sounds better than "WRONG"
Reply #8June 15, 2009, 12:34:29 pm
« Reply #8 on: June 15, 2009, 12:34:29 pm »
Sorry, didn't mean to sound that way.  Just wanted to provide pertinent information.  :)
