Oil cooler!
Topic: Oil cooler! (Read 2767 times)
June 12, 2009, 04:43:26 am
Mozza
Oil cooler!
June 12, 2009, 04:43:26 am »
Ok i have just bought a new oil cooler and wanted to know if any one could post how to change it on my 1.6 gtd, as i cant find a haynes manual for diesel mk2's
June 12, 2009, 05:10:03 am
arb
Re: Oil cooler!
June 12, 2009, 05:10:03 am »
if you have an OEM design, its only held on with a NPT nut on the threaded stud the filter screws to... this threaded stud / pipe is about an inch longer than the stock pipe. There will be a gasket similar to what every oil filter has that seals the top of the cooler to the filter flange on the engine. Did you get the longer pipe with it and the nut ? Or, did you already have an oil cooler you are changing ?
June 12, 2009, 08:20:21 am
Mozza
Re: Oil cooler!
June 12, 2009, 08:20:21 am »
just bought an oil cooler from gsf which is a box shaped item with two hose points facing opposite ways, and a rubber seal,
June 12, 2009, 08:32:13 am
Mozza
Re: Oil cooler!
June 12, 2009, 08:32:13 am »
this is kind of what mine looks like
June 12, 2009, 10:24:46 am
arb
Re: Oil cooler!
June 12, 2009, 10:24:46 am »
Looks like mine. You will need the longer pipe if it was not in the box.
June 12, 2009, 11:28:13 am
Mozza
Re: Oil cooler!
June 12, 2009, 11:28:13 am »
no nothing in the box, what leingth pipe will i need and is it just longer rubber hose
June 12, 2009, 11:47:28 am
arb
Re: Oil cooler!
June 12, 2009, 11:47:28 am »
Quote from: Mozza on June 12, 2009, 11:28:13 am
Sorry, I should have been more clear... there is a threaded steel pipe in the center of the filter flange on your block. It is what your filter screws onto. You will remove it. The new pipe will the same diameter / threads, but be a bit longer. If you put it next to your cooler, you will simply add the height of the cooler to the length of this pipe. There is nothing special about it beyond that. You will also need a low profile nut to secure the cooler to the flange. If you don't use one, you will have some non-filtered oil by-passing the filter by leaking past the pipe. Besides, the cooler will fall off the flange every time you change the filter.
June 12, 2009, 03:09:45 pm
Baxter
Re: Oil cooler!
June 12, 2009, 03:09:45 pm »
Remove oil filter, which is a bit of a twat in itself.
Remove 27mm nut.
Remove 2x water hoses.
Remove oil cooler.
In true haynes fashion, refitting is reverse of removal.
June 13, 2009, 02:38:11 am
Mozza
Re: Oil cooler!
June 13, 2009, 02:38:11 am »
cheers guys thankyou?
June 14, 2009, 11:31:22 am
smutts
ClackClackClackClackClack
Re: Oil cooler!
June 14, 2009, 11:31:22 am »
Was this a replacement for one leaking oil into the coolant? A few changes of plain water and washing powder will work wonders in getting all that sludgy crap out. DON'T USE WASHING SODA, OR CAUSTIC SODA or SODIUM HYDROXIDE! as these will be fantastic at dissolving oil, human flesh and aluminium engine components. Enjoy!
June 15, 2009, 01:59:41 am
Mozza
Re: Oil cooler!
June 15, 2009, 01:59:41 am »
Well i do hope this will fix the oil in coolant problem and cheers for the hint with the washing powder, I just hope to god its not the head gasket.
Oil cooler!
