Author Topic: T3 problems  (Read 3770 times)
June 08, 2009, 07:17:03 pm
dieselherb1
  • 354
T3 problems
« on: June 08, 2009, 07:17:03 pm »
I need to clock the exhaust side of a T3 so I can mount it on a TDI engine. I tried to remove the bolts on the exhaust side and broke most of them. Now I can not get it apart. I've used PB Blaster and beat on it in a vise but afraid I'll break the casing. How can I get it to turn or come apart?
Thanks
Reply #1June 09, 2009, 05:44:41 pm
dieselherb1
  • 354
Re: T3 problems
« Reply #1 on: June 09, 2009, 05:44:41 pm »
Thanks I'll try that. Same method for removing broken studs?
Reply #2June 09, 2009, 06:49:20 pm
cyrus #1
  • 360
Re: T3 problems
« Reply #2 on: June 09, 2009, 06:49:20 pm »
but certainly heating it extensively and shocking it with penetrating oil can do wonders.
Indeed.  At work, when faced with a broken bolt or stud we would always try welding first.  Even if it didn't work well enough to spin the bolt out, it usually anneals the material.  This makes it miles easier to drill out, if it comes to that.
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
