General Information
General
How to pull the motor?
Topic: How to pull the motor? (Read 5901 times)
May 31, 2009, 08:21:34 pm
veedubcanuck
May 31, 2009, 08:21:34 pm »
What is the best way to pull the motor? To do it with the tranny still attached? Or to separate them in the car? Car is a 93 golf AAZ manual trans, no AC. I want to re-build the engine.
Thanks!
2003 Jetta GLS 1.8T w/ Upsolute software 20k kms (yes 20)
1993 Jetta GL 1.9TD stock 440k kms
1990 Jetta 1.6TD stock 320k kms
1993 Golf GL 1.9TD stock 401k kms
1991 Jetta 1.6TD Stock 587k kms
May 31, 2009, 09:55:25 pm
catlin_cava
Re: How to pull the motor?
May 31, 2009, 09:55:25 pm »
I'm going to take the complete front off my 97, and disconnect the drive shafts and pull it out the front. Doing that tomorrow
Catlin
2010 VW Golf City 2.0L "Hers"
May 31, 2009, 10:34:13 pm
May 31, 2009, 10:34:13 pm »
Part of the answer depends on what equipment you have.
Those with a cherry picker or overhead winch seem to like to lift the complete unit (engine and tranny) up thru the top.
I own a floor jack and so always pull the front end off and then roll the complete unit forward and out. I've never had a problem with broken bumper bolts, but that's just me.
Either way, most folks find it easiest to leave the engine and tranny bolted together for removal, and most will pull the A/C compressor first and tie it out of the way to prevent needing to recharge the system.
June 01, 2009, 06:57:24 am
veedubcanuck
June 01, 2009, 06:57:24 am »
Perfect. Thanks guys.
June 01, 2009, 01:50:53 pm
catlin_cava
June 01, 2009, 01:50:53 pm »
Up and out. 4 hours motor tranny and axels all out. Beat that time:P
Catlin
June 03, 2009, 10:40:44 am
turborabbit
User+
June 03, 2009, 10:40:44 am »
Depends on the reason for the re-build. If you're just looking for starting compression, do it "in frame". I can vacuum test the head, ring and incert it in less time than most can pull the motor. If I have to do more I drop it out the bottom. Good luck-warren
If "the more you know, then the more you know, you don't know, then I've got a lot to learn, since I'm forgetting what I thought I knew!!
01Dodge TD
81 Caddy TD
84 Winnebago/Renault TD
86Jetta84GolfCaddyCaddyCaddyCaddy
June 03, 2009, 12:05:47 pm
spdrace11
User+
June 03, 2009, 12:05:47 pm »
Quote from: catlin_cava on June 01, 2009, 01:50:53 pm
Done it in 1hr, but ive done it more than i care too.
91 VW Jetta diesel coupe 1.6 NA 5spd, 91 Jetta 1.6 NA, 81 Caddy 1.6NA
General Information
General
