again.....
Topic: again..... (Read 3057 times)
May 28, 2009, 08:02:00 pm
96jetta
again.....
May 28, 2009, 08:02:00 pm »
the jetta has been running great ever since i did the head a while back however... i went to start it tonight to go for a drive and i started fine but then after ideling for a min it started to put out alot of white smoke that smelled like diesel. the timing is all in line (pump cam crank) and none of the lifters have any damage
. any thoughts as to whats going on?
May 28, 2009, 08:23:16 pm
macka
Re: again.....
May 28, 2009, 08:23:16 pm »
bad injector?
Quote from: Vincent Walden
I do know that I drive torque, while listening to my friends prattle on about horsepower.
May 28, 2009, 08:23:44 pm
veedubcanuck
Re: again.....
May 28, 2009, 08:23:44 pm »
Does it sound like it's missing or sound different? Maybe water or air in the fuel lines/filter?
2003 Jetta GLS 1.8T w/ Upsolute software 20k kms (yes 20)
1993 Jetta GL 1.9TD stock 440k kms
1990 Jetta 1.6TD stock 320k kms
1993 Golf GL 1.9TD stock 401k kms
1991 Jetta 1.6TD Stock 587k kms
May 28, 2009, 08:25:44 pm
veedubcanuck
Re: again.....
May 28, 2009, 08:25:44 pm »
Did you take it for a drive to see what happens?
May 28, 2009, 08:37:57 pm
96jetta
Re: again.....
May 28, 2009, 08:37:57 pm »
na just left it in the drive way. there the origional injectors after 275xxx kms bad i guess? i didnt see any air bubbles but it was dark out too ill look in the morning to see.
May 28, 2009, 08:44:12 pm
96jetta
Re: again.....
May 28, 2009, 08:44:12 pm »
as for the soumd part it sounded like it was sputtering and the motor speed was fluttering from about 1100rpm to about 800rpm
again.....
