Author Topic: again.....  (Read 3054 times)
May 28, 2009, 08:02:00 pm
96jetta
again.....
« on: May 28, 2009, 08:02:00 pm »
the jetta has been running great ever since i did the head a while back however... i went to start it tonight to go for a drive and i started fine but then after ideling for a min it started to put out alot of white smoke that smelled like diesel. the timing is all in line (pump cam crank) and none of the lifters have any damage  ???. any thoughts as to whats going on?
Reply #1May 28, 2009, 08:23:16 pm
macka
  • 957
Re: again.....
« Reply #1 on: May 28, 2009, 08:23:16 pm »
bad injector?
Quote from: Vincent Walden
Reply #2May 28, 2009, 08:23:44 pm
veedubcanuck
  • 151
Re: again.....
« Reply #2 on: May 28, 2009, 08:23:44 pm »
 Does it sound like it's missing or sound different? Maybe water or air in the fuel lines/filter?
Reply #3May 28, 2009, 08:25:44 pm
veedubcanuck
  • 151
Re: again.....
« Reply #3 on: May 28, 2009, 08:25:44 pm »
 Did you take it for a drive to see what happens?
Reply #4May 28, 2009, 08:37:57 pm
96jetta
Re: again.....
« Reply #4 on: May 28, 2009, 08:37:57 pm »
na just left it in the drive way. there the origional injectors after 275xxx kms bad i guess? i didnt see any air bubbles but it was dark out too ill look in the morning to see.
Reply #5May 28, 2009, 08:44:12 pm
96jetta
Re: again.....
« Reply #5 on: May 28, 2009, 08:44:12 pm »
as for the soumd part it sounded like it was sputtering and the motor speed was fluttering from about 1100rpm to about 800rpm
