Author Topic: Hydraulic lifter test  (Read 3816 times)
May 02, 2009, 10:44:52 am
Golf/Jetta
  • 102
« on: May 02, 2009, 10:44:52 am »
is there a way of testing the Hydraulic lifters?
or the way the supposed to act/feel?
stiff? spongy? is there a spring inside?
'97 Jetta - 4Dr - 1.9 TiDi (Forth Car)
'94 Jetta - 4Dr - 2.0L Swaped in an AZZ - Almost done 2011 b4 Winter (Third Car)
Blue '87 Golf - 2Dr - Tags (First Car)
Red '92 Jetta (W) - 4Dr - Sold to Friend For $200 (Second Car)
Thanx For Answering My Posted Question's/Comments...
Reply #1May 02, 2009, 12:20:46 pm
« Reply #1 on: May 02, 2009, 12:20:46 pm »
Yup... the Bentley has the full procedure, but the basics are:
- get the engine up to operating temperature and then shut it off
- quickly remove the valve cover gasket
- with a non-marking stick (wood etc) press down on each lifter in turn
- they should only depress 0.1mm (0.004 inches) with normal hand pressure
Reply #2May 02, 2009, 11:27:24 pm
  • 3468
    • McScrubbins Body Wash
« Reply #2 on: May 02, 2009, 11:27:24 pm »
Leave it to Vince!
